1 members (Danielbolt),
164
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | I picked up a pair of clutch and brake pivot bushings from Jim Carter for my 45 1.5 ton truck. I have the assembly off and haven't had a chance to take a hard look, just a quick one at dirty parts but I didn't see any sign of bushings. Are they worn away or is the idea here to over bore the hole in each pedal and then install the bushing to bring the clearance back to tolerance?
Anybody done this before and clue me in?
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I'm NOT familiar with the Big Bolts but all the ones I've seen have bushings in them. They are sometimes so thin you can hardly see them, and sometime they may be worn completely away on about half of it. Sometimes these replacement parts need to be reamed a bit after you put the bushings in.... oh, and if it has bushing a tip to putting them in is to put them in the freezer for a while and they will usually drop into the pedal holes...then fit them to the shaft. .... all this is my opinion. Maybe someone will come along that has one like yours. Hang tight. | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Thanks for that! I'm pretty sure the assembly is identical to the ones used in the 1/2 and 3/4 ton trucks.
I like the tip about the chilling the bushings to shrink them!
-Mike-
