2 members (Ponchogl, Hush), 67 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#839763 03/30/2012 12:27 AM
brake cylinder ran out of fluid... what to do...on a 48 gmc 1/2 ton
696969 #839770 03/30/2012 12:59 AM
3B Offline
Hy 696969, look under the truck and see if you can see a wet spot on the floor or on the back of the tires, If you can't find any evidence of a leak, it's time to pull off all the wheels and drums and try to locate the leak. I would strongly recommend a complete rebuild of the entire braking system at this point, and don't forget your flex lines, hope that helps.
3B #839814 03/30/2012 2:54 AM
3B is right on. I would add that if there is no sign of a leak at the wheels be sure to look along the chassis rail for a rusted hole in the line....but 3B's advice is right on. We have to be able to STOP once we get going.
3B #839998 03/30/2012 11:43 PM
i will look around and will get back to you...thanks
696969 #840119 03/31/2012 1:41 PM
i see that they have brake lines already bent to fit truck... wondering if the bends are that close...also would you recommend rebuilding brake cylinder or buying new one...
696969 #840131 03/31/2012 2:35 PM
Pre-bent lines have been good fits on my trucks.
Look at the bores in the brake cylinders. If they are pitted replace them. If they are not pitted, hone and rebuild them.
As mentioned above, replace the three rubber flex lines.
tclederman #840204 03/31/2012 8:21 PM
thanks for info..will have to by some i get some money..
