1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#83921 10/08/2007 4:34 PM
I've got a broken water pump bolt on a chevy 350. Not that big a problem, right? Well, it must have been grade 8 cause it will not drill.I finally got enough drilled out and easy out, with heat, broke off inside the bolt. Now can't get either out.
Thought about making a stud, but block is cast, so cannot weld it. Does anyone think a good brazing job would work well enough for a water pump stud? Or am I on the way to the machine shop?
#83922 10/08/2007 4:57 PM
3B Offline
Hy 57Chev, you are facing every mechanics worst nightmare, I don't know if your engine is in a vehicle or out, if it's in we know it's a major job to pull it just to get one bolt out, but with the easy out broken off in it, it cannot be drilled with anything less than a carbide drill. Personally I would bite the bullet and pull it and take it to a machine shop to have it removed, good luck.
#83923 10/08/2007 6:06 PM
H Online: Content
A broken-off EZ out is a real pain. You can heat it cherry red with a torch, and let it cool slowly, and it will soften enough to be drilled out, particularly if you use a solid carbide drill bit. The trick is to be sure you drill only the EZ out and the surrounding screw, not the block material. I'd suggest pulling the engine, and stand the block up under the spindle of a slow-speed drill press. Trying to keep doing the repair in place with hand tools is a good way to ruin the block for good.
#83924 10/09/2007 4:23 AM
A good welder could weld a nut on to the remains. The heat of welding it can break them loose. If it's cross threaded (which I doubt it could be), it probably won't come out that way,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#83925 10/09/2007 7:24 AM
I did a similar thing with an exhaust manifold stud on a BMW. I called a machine shop and they recommended a local guy that did nothing but extract broken bolts and studs. He had a step van that he worked out of- he charged me $75 and removed the broken easy out from the stud right in my driveway. It was worth every penny.
Paint & Body Shop moderator
#83926 10/10/2007 3:39 PM
this is the same tip i have in our antique motocycle magazine
only this one is right here on the bolt. check out this tech tip.
only change is to place a washer (if possible) under the nut you weld on :p
http://www.stovebolt.com/techtips/brokenbolt.htm
Jim & Caroline
