2 members (J Lucas, Erniegp), 78 guests, and 2 robots.
Topics128,054
Posts1,055,780
#838722 03/26/2012 11:03 AM
1952-3100. Hooking up new 12V heater motor and sw. The sw. is a "standard" universal switch. There are two connection posts on the back. Is it correct to say that the red (hot) wire from the motor should go to the terminal that has what looks like a fuze with a wire wraped around it, or does hot go to the stand alone post? Then the black (ground) would go to the other one. Naturally a hot from ignition sw. goes in the same place as hot from motor. Right? Thanks
'52 3100 "once a Marine, always a Marine!!
If your switch looks like This
It should be wired like This
The switch grounds by being clamped to the dash
If that is not your switch disregard this post.
That switch has a light in the knob and if wired backwards the light will be on all the time, the light should come on only when the heater is running.
Ex Hall Monitor
Ex Hall Monitor
.....AND if it's like mine the light gets brighter the faster the fan blows.
Tiny #838884 03/26/2012 10:29 PM
OK thanks. Yes my heater sw. looks like that, it even has a light that I didn't even see. Black wire coming off motor just goes to a seperate ground then. 10-4 thanks again, I just didn't want to burn up new parts!!!!
My motor was originally grounded to the case
...pic...
...pic...
I grounded my new 12v the same way
Just to be clear, the switch needs no ground. The switch is just a conduit for power between the battery and the heater. The actual ground comes from the heater motor itself.
Jeff
My 1953 Chevrolet
1947.1 Gallery
Jeff
It needs to be grounded for the light to work
And it may "smoke" the first time you send power through it. But that is normal. And as far as "looks like a fuze with a wire wraped around it" don't let ANYTHING touch the "spring" as it will get super hot, fingers, wires......that kind of thing
....David
Thanks! Somehow I blanked out at that part. I didn't even know these came with lights.
Jeff
My 1953 Chevrolet
1947.1 Gallery
THANKS EVERYONE
