4 members (66flea, 1955 1 Series, UtahYork, Deegs53), 311 guests, and 4 robots.
Topics128,156
Posts1,057,018
Members48,460
how the heck do i replaces these? i want to break them free but leave them in so i can doing some powder coating then install the new ones.....thanks for any info guys
Ball joints on a '51?
That's what I was thinking.
Does your truck have the stock suspension, or has it had an ifs swap? Or by "balljoints", do you mean the ball and socket style tie rods and drag link?
Bill Burmeister
it is stock suspension.....
You are asking about the joints that join the drag link to the pitman arm on one end and the steering arm on the other, correct? Unscrew the large pug on each end, take out what parts you can and pop the ball stud out the side. If the ball is round and smooth then a simple rebuild kit will do. If you need to remove the balls, let us know.
1951 1 Ton Completed
Here is a link to the tech tip article on removing the ball studs. tech tip article
Tim
1951 3100 Chevrolet
....there is also a few pics in my photobucket that may help if you have to remove the ball stud.
thanks guys!
I just remove the ball stud on my pitman arm yesterday. I ground down the peened end flush with pitman arm, but no amount of pounding would get the stud to start moving. I drilled out the center of the stud with a 3/8" drill bit, still no go. I then chamfered the ground down end of the stud (around the hole I drilled) with my dremel tool. Bingo, the stud easily came out. Both ends of the hole in the pitman arm were chamfered by the factory (the peened side more so than the ball side).
DavidF...thats food for thought. I did notice the side the ball stud goes in first was chamfered but not the peened end. I must have ground down the peened end so far the chamfer was gone!!!
I don't think there is consistency with the pitman arms. Some report chamfer and others say no chamfer even within the same model year. The chamfer on mine was rather large…maybe 1/8" or so. Best advice when removing ball stud is to assume it is chamfered.
