2 members (Otto Skorzeny, baldeagle), 107 guests, and 1 robot.
Topics128,037
Posts1,055,467
Members48,424
#836856 03/20/2012 11:53 AM
ok so i thought i had a 216 cause of the thriftmaster valve cover... but got these numbers of the block is it a 235?
3837004gm and 0028586t55z
all your help is wery appriciated! thumbs_up
chally #836875 03/20/2012 12:59 PM
Thriftmaster just refers to the standard 216/235 engine, depending on the year.
Almost all 216 engines and most pre-1954 235 engines had 2 bolts (often with "acorn" nuts) holding the valve cover to the head.
Later 235 and all 261 engines had 4 machine screws (sometimes they were 1/4"x20-thread pan-head "stove bolt" screws) on the sides of the valve covers.
T55Z indicates a 1955 car engine (manual transmission) made in Tonawanda, NY. It came with mechanical lifters.
3837004 is a 235 block casting code used from 55-57
tclederman #836908 03/20/2012 2:51 PM
cool thanks man guess i have a car 235 engine in my 1952 1/2 truck well im not sad! now i can order a dual carb intake!
do you know if these engine came with dual exhaust original?
the dual manifold says gm so i guess they did!
chally #836915 03/20/2012 3:03 PM
You may have a Corvette exhaust manifold. Looks like you have a piece of nostalgia on that old 'bolt.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #836918 03/20/2012 3:07 PM
you say what? corvette? headscratch
i can take a picture and put it up here
for you guys to see?
chally #836919 03/20/2012 3:08 PM
Don't be sad, that's a good motor and you can make it look a lot like a 216 if you want, but it will serve you well. You can get dual everything for this motor, only factory dual exhaust was for the '53 and 54 Corvette 235s.
Check out www.patricksantiquecars.com online catalog, lots of good info on your motor as well as add on speed goodies.
Best of luck
Jim
1946 1/2-Ton Chevy
You can host pictures on a site like photobucket, and then post a link to the picture here.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #836927 03/20/2012 3:28 PM
chally #836928 03/20/2012 3:29 PM
well theres some pictures pleas chime in if you know anything
bout it
chally #836952 03/20/2012 4:43 PM
also found this number on the exhaust
gm 3835587 i think
chally #836960 03/20/2012 5:04 PM
head stamping 3836848
chally #836964 03/20/2012 5:16 PM
Sorry I can't tell anything about the exhaust on your photos (off 90 degrees) and hard to look at. I can only see one exhaust pipe outlet but too hard for me to tell.
The "848" head is slightly higher compression and therefore is thought to be desirable. Valve sizes are the same as a std 235 head however so it's something I don't understand unless that heads has lumps. You may have a pretty good engine there. Someone will know for sure.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #837013 03/20/2012 8:36 PM
I can see the two pipes, but I can't tell you anything. I'll bet with more pics, someone will know something!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Mr. Lang #837036 03/20/2012 9:56 PM
i`ll get better pics tomorrow if any one have a picture of a
corvette manifold i can see if its similar aswell?
chally #837041 03/20/2012 10:04 PM
DADS50 #837129 03/21/2012 3:06 AM
Pow~! That sure looks like Chally's set up.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Mr. Lang #837142 03/21/2012 3:29 AM
Chally's casting number is not the same as the one in the webshots link
His vacuum port looks different also.
Very nice set up he has
DADS50 #837195 03/21/2012 6:09 AM
I saw a 235 with the Corvette exhaust and a vintage Offy intake go for stupid money at an auction a few years ago. The engine was seized beyond belief too. Good find Chally!
"The Fake Truck"
Whitedog #837203 03/21/2012 7:54 AM
hhmmmm the area where the stamping number is doesnt look the same
on the corvette intake its kinda curvy but on mine its more like a straight edge...
i`ll get some better detail pics up later today
thank you all for the help thumbs_up
chally #837214 03/21/2012 10:46 AM
clifford has a nice 4 barrel intake that works very well from what I have heard, I know I'm putting one on my truck.
brokenhead #837607 03/22/2012 10:51 AM
chally #837608 03/22/2012 10:52 AM
chally #837622 03/22/2012 11:50 AM
It looks as if Chally has a split exhaust manifold, not a Corvette six.
Hoyt
hoyt #837669 03/22/2012 3:52 PM
i didnt think i had a corvette six and i dont think the
dual exhaust looks like the corvett manifold either....
so moving along im going for a dual carb setup on this so
what manifold will go best with the exhaust manifold
offenhauser, fenton or others?
any thougts are welcome
