9 members (Peggy M, Shade Baby, klhansen, cmayna, Rusty Rod, David Bush, greenie-reddy, Cosmo, 1 invisible),
69
Mod | | | Forums66 Topics128,074 Posts1,055,913 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 58 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 58 | Looking for some advice on aftermarket/repro.wiring harness.Found a couple of websites that offer the original style,however they are way out of my budget.Just want to make the truck safe to drive this summer.Also came across harness from Jim Carter and Classic. Has anyone you might know ever purchased one of their harnesses? And are they as user friendly as they say? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I used one from Classic on my 1952. It was very user friendly, had everything needed, and fit just right. I ordered it for a 6 volt system even though I knew I would be running a 12v generator system. I think the wires gauge is okay for 12v but it seems small to me to use in a stock 6v system.
Chuck | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | I like the harness that I got from Classic Parts. No problems installing it or since. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I have Classic too.But,if you're not looking to restore to stock layout, Speedway Motors has a 12 circuit update harness for $139.
http://www.speedwaymotors.com/Economy-12-Circuit-Wiring-Harness,2352.html?parentDisplayId=2358
Drew
| | | | | Joined: Sep 2010 Posts: 166 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 166 | Mine is from Classic also, A plus, no problems. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Wiring a truck of your vintage is quite simple. I did my own and I am no wiring expert. I followed the schematic in the shop manual and replaced one wire at a time. If you are 12 volt the wire gauge on the schematic is fine. You need a good crimping tool and do a pull test of each connector once its crimped. Having said that the most difficult part for me is under the dash. Basically because of location. However even with an aftermarket kit you still have to access it. | | |
