0 members (), 117 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
#835896 03/16/2012 11:43 PM
Looking for some advice on aftermarket/repro.wiring harness.Found a couple of websites that offer the original style,however they are way out of my budget.Just want to make the truck safe to drive this summer.Also came across harness from Jim Carter and Classic. Has anyone you might know ever purchased one of their harnesses? And are they as user friendly as they say?
I used one from Classic on my 1952. It was very user friendly, had everything needed, and fit just right. I ordered it for a 6 volt system even though I knew I would be running a 12v generator system. I think the wires gauge is okay for 12v but it seems small to me to use in a stock 6v system.
Chuck
I like the harness that I got from Classic Parts. No problems installing it or since.
I have Classic too.But,if you're not looking to restore to stock layout, Speedway Motors has a 12 circuit update harness for $139.
http://www.speedwaymotors.com/Economy-12-Circuit-Wiring-Harness,2352.html?parentDisplayId=2358
Drew
Mine is from Classic also, A plus, no problems.
Wiring a truck of your vintage is quite simple. I did my own and I am no wiring expert. I followed the schematic in the shop manual and replaced one wire at a time. If you are 12 volt the wire gauge on the schematic is fine. You need a good crimping tool and do a pull test of each connector once its crimped.
Having said that the most difficult part for me is under the dash. Basically because of location. However even with an aftermarket kit you still have to access it.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
