2 members (Jim K, Lightholder's Dad), 114 guests, and 0 robots.
Topics128,163
Posts1,056,918
Members48,458
Mystery Box
So this box with a knob that slides horizontally is hooked up under the dash. I have no clue what it is and what it is supposed to do.
My google searches are too general to come up with any results.
Any guesses?
'64 C10 1/2 ton fleetside
something to do with pulling a trailer???? ...my GUESS.
Yes, looks like a controller for electric trailer brakes. Should have a bunch of wires attached.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Electric brake control box.I had one on a 1966 3/4 ton truck just like that one.I want to say it had a copper line that ran to a T in the master cylinder brake line.I don't think it had very many wires to it,but I can't remember.
Tim
1951 3100 Chevrolet
Its a Kelsey Hayes brake controller. Electronic ones are still being made. http://www.hayesbc.com/
That's the older design trailer brake controller that incorporates a hydraulic connection to the master cylinder. It will have a power wire connected to battery voltage, an output line going to the trailer brakes, and a smaller-gauge third wire connected to the brake lights. It works with either hydraulic pressure from the brakes, or manually by moving the handle side to side. The knob turns to adjust the sensitivity, so the output to the trailer can be reduced when running unloaded to avoid locking up the trailer brakes. Later model electronic controls don't have the hydraulic connection because it interferes with anti-lock brake systems.
Have had several trucks and vans with trailer brake controllers. Would have to agree with everyone else that's what you've got.
I had that exact same model electric brake controller on my '73 C10.
Boy, that brought back some pleasant memories.........
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Socket Breaker
Socket Breaker
It looks exactly like the one that was on my '65 c10 when I bought it.
I left it on there until it started leaking brake fluid from the box itself.
the one I used to have
If everything is still there, a big honking 6 or 7 prong plug box should be on the back somewhere.
-W
and when you push on the brake pedal the knob would move.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
