3 members (Paul_WNC, Phak1, thekid1950), 43 guests, and 5 robots.
Topics128,012
Posts1,055,320
Members48,419
#835868 03/16/2012 10:02 PM
i have a 2 part window frame in my 37 i need some advice on something the frame is fixable but it has some a wedge/bracket inside the window frame thats broken or missing depending on which side your checking its just a sliver of metal with threads in it is there some place i can buy those or will i have to fabricate them
1937 1/2 ton
Daniel, are you talking about the windshield frame? I just want to be sure.
If its the windshield frame I believe you can buy what you need seperate at Chev's of the 40's....maybe others? Its about a 2" long piece of metal "bar" and it has the threaded holes in it for the screws that go through the inside of the frame.
I've got an extra set but the bolter that gave them to me said I must hold onto them!!
yep thats what i ment i think lol i will check those
1937 1/2 ton
frown chip didnt see the peices anywhere on those sites only whole windsheild frames if you find it link it to me
1937 1/2 ton
Daniel here you go.
http://www.parts123.com/parts123/yb.dll?parta~partsort~A2~cadefefx
Its the Filling Station an it should be about the 5 or 6 item down. I think they called it windshield frame BRACKETS.
Hope this is it. Let me know.
Edit: I don't know why the link didn't highlight in blue but if you go to the web site the part number is FS78 and the brackets are $20 for the pair.
