Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (Samantha, baldeagle, SandraD, farmallb), 44 guests, and 1 robot.
Topics128,005
Posts1,055,261
Members48,418
#832841 03/06/2012 11:22 PM
When I honk my horn, I get shocked when I'm touching metal (door handle, door, etc.). Any ideas why? Yeah, I know, I must have wired it wrong.
Thom Masterson
Bats62Chevy #832867 03/07/2012 12:41 AM
Maybe you just need new bumper brackets. No, wait. That's not it! LOL!! (Private joke)
It must be a bad ground but that's merely a guess. I'm sure that some one will give a more thorough answer. Just curious, does the horn sound weak or strong? and does it honk even when you don't get a shock (i.e. not touching any other metal)?
Lugnutz #832909 03/07/2012 2:45 AM
Try running a body ground from the cab to the engine and maybe another to the frame,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #832911 03/07/2012 2:48 AM
a body ground? would i run a wire from the body directly to the engine AND the frame?
Thom Masterson
Bats62Chevy #832939 03/07/2012 3:58 AM
The Factory Assembly manual shows the size and locations of the original grounding straps, if you chose to do it the way it was done at the plant. You can purchase grounding straps at your FLAPS.
thanks guys!
Thom Masterson
Bats62Chevy #833020 03/07/2012 12:45 PM
It's not a wire it's a grounding strap. As Tony eluded to, if you go to your local parts store, such as NAPA, and tell them you need a "Grounding Strap" they can hook you up with the correct part.
Most are braided copper and look like this: http://inlinethumb16.webshots.com/48271/2336585610103882008S600x600Q85.jpg
Hot Rod John #833073 03/07/2012 4:14 PM
It's the steering column that's not grounded not the cab. He says he's getting a shock if he touches anything metal- doors, handles, etc.
If the cab needed grounding then he wouldn't be complteing the circuit with his body.
He needs to check his column mounts or add a ground wire to them.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
johntsmith #833143 03/07/2012 8:22 PM
John's solution sounds better
gazim #833172 03/07/2012 10:44 PM
The rag joint at the steering box has a small strap to ground the horn. I'd bet it is missing/broken.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
64fleetside #833208 03/08/2012 1:22 AM
I just got done looking under the hood and under the driver front fender. I didn't see any straps or grounds connected to the frame or cab coming from any part of the steering column or box. I'm curious to know what a "rag joint" is though. Would I use a grounding strap and connect it to the frame or the cab metal from the "rag joint"?
As always...Thanks in advance!!!
Thom Masterson
Bats62Chevy #833249 03/08/2012 3:17 AM
...I'm curious to know what a "rag joint" is though.
The rag joint looks similar to this:
http://www.performanceonline.com/images/T/t-16596-352.jpg
and it is the connector that attaches the steering column shaft to the steering box, as shown in this photo.
http://img.photobucket.com/albums/v685/dano69c10/ColorsTruckPics013.jpg
Hot Rod John #833260 03/08/2012 3:55 AM
so...if there was a ground strap that connected to the rag joint, wouldn't it spin while i turned the wheel?
Thom Masterson
Bats62Chevy #833263 03/08/2012 4:07 AM
No the ground strap is a small peice of brass that simply connects one foot of the steering shaft to one of the feet on the input shaft of the steering box. It is pinched under the bolt or rivet and sandwiched between the foot and the rubber "rag joint". It simply bridges the rubber from one side to the other since rubber is nonconductive. Hope this helps Lyle
65 K10 Longbox Fleetside Big Back Window Custom Cab
65 K10 Flatbed
Old School Parts 60-66
(208)946-6173
[email protected]
Bats62Chevy #833300 03/08/2012 6:03 AM
I'm sure that everyone is on the right track. Right now I don't seem to be able gather up enough brain cells to see where the problem might be; but when I was a small lad I found out quite by accident what causes the shock. I had a bicycle with a horn. Since I took everything apart, I took the horn out. While holding the wires for the horn I touched then to the two "D" cells that usually powered the horn. As long as the horn was sounding - no shock. As soon as one of the leads came off you got quite a shock.
I found out about collapsing fields and how their voltage is much higher than the source voltage. I wonder if you get a shock while the horn blows or after? John
552burb #833341 03/08/2012 1:34 PM
Thanks for the input guys. John...I get shocked when the horn sounds. Lyle...thanks for the info. This rag joint is an interesting part to me. I wonder why the engineers place a piece of rubber in-between the connection. By the looks of the picture that HotRodJohn sent, there are enough nuts and bolts on this thing that would warrant any type of movement whatsoever. I'll look more closely at this issue this weekend.
Thom Masterson
Bats62Chevy #833594 03/09/2012 4:51 AM
The rubber was put in there to help isolate road vibration, just like rubber cab mounts, as well as provide a shear zone in the case of a major collision.
65 K10 Flatbed
(208)946-6173
[email protected]
66Suburban #833652 03/09/2012 2:10 PM
If you have lost the ground at the rag joint, it's a pain to fix. So if you are not going for the ultra factory correct look, there are 2 easy places to add the ground. Under the dash where the column connects to the ebrake plate or outside on the firewall where the column is secured to the firewall.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
