4 members (Gdads51, Shaffer's1950, BarryP, Robert Crandall), 79 guests, and 1 robot.
Topics128,150
Posts1,056,985
Members48,460
#831702 03/03/2012 1:53 AM
Due to a large hole in my gas tank, I guess it will have to be replaced. Lots of pickup tanks listed but can't seem to find one for a suburban (I imagine the panel would also be the same ) Any leads would really be appreciated. Thanks...
the panel/burb tanks are not reproduced - you're looking for used, a post in the parts wanted might find one eventually
..I do NOT know about the 55 2nd series but I do know about the AD's.
Jim Carter has had the repop panel/burbs/canopy express gas tanks for at least two years now. I bought one of them.
See this pic.... My rusted out old one...a NEW one and an old one I was going to try salvage. I must admit, the repop is a nice one. Heavy and exactly like the old ones.
Maybe a phone call would confirm whether or not there is one for the TF panels.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Fueltanks002.jpg
Sir Searchalot
Sir Searchalot
Should try to fix. Not available as Red58 said. Hard to find in useable condition. They can be fixed by someone way far away from your house. There are safe ways to weld on them. See the web.
And I thought mine was rusted! Thanks for the pics. Did call a couple of suppliers. None of them could help. May have to pony up to a custom. Thanks
If you find one please let me know. I am in the same boat, so to speak.
"Upon the plains of hesitation bleach the bones of countless millions, who when on the dawn of victory paused to rest, and there resting died." - John Dreschmer
Maybe you could make something from a later model (mid '70s) pick-up work they look about right.
Les
I've also heard but cant confirm that early 80's chevy blazer tanks are close fit. I put an early 80's el camino tank between the rails in the back. Only drawback is no room for spare tire.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
I have 2 gas tanks for the 55 suburban. One was hit pretty hard in the front and has been patched. The other one does not leak, but has a couple of dents on the bottom where it bottomed out on something. Does anyone have an idea what these would be worth? Is this the correct place to ask that?
Broke down and bought a stainless tank that mounts at the rear of the frame. A bit pricey but one less thing to worry about.
