3 members (Woodcmiami, Cosmo, 1 invisible),
75
Mod | | | Forums66 Topics128,150 Posts1,056,991 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 14 New Guy | | New Guy Joined: Nov 2011 Posts: 14 | Due to a large hole in my gas tank, I guess it will have to be replaced. Lots of pickup tanks listed but can't seem to find one for a suburban (I imagine the panel would also be the same ) Any leads would really be appreciated. Thanks... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the panel/burb tanks are not reproduced - you're looking for used, a post in the parts wanted might find one eventually
Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..I do NOT know about the 55 2nd series but I do know about the AD's. Jim Carter has had the repop panel/burbs/canopy express gas tanks for at least two years now. I bought one of them. See this pic.... My rusted out old one...a NEW one and an old one I was going to try salvage. I must admit, the repop is a nice one. Heavy and exactly like the old ones. Maybe a phone call would confirm whether or not there is one for the TF panels. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/Fueltanks002.jpg | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Should try to fix. Not available as Red58 said. Hard to find in useable condition. They can be fixed by someone way far away from your house. There are safe ways to weld on them. See the web.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Nov 2011 Posts: 14 New Guy | | New Guy Joined: Nov 2011 Posts: 14 | And I thought mine was rusted! Thanks for the pics. Did call a couple of suppliers. None of them could help. May have to pony up to a custom. Thanks | | | | | Joined: Apr 2012 Posts: 37 New Guy | | New Guy Joined: Apr 2012 Posts: 37 | If you find one please let me know. I am in the same boat, so to speak.
"Upon the plains of hesitation bleach the bones of countless millions, who when on the dawn of victory paused to rest, and there resting died." - John Dreschmer
| | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Maybe you could make something from a later model (mid '70s) pick-up work they look about right.
Les | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | I've also heard but cant confirm that early 80's chevy blazer tanks are close fit. I put an early 80's el camino tank between the rails in the back. Only drawback is no room for spare tire.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Jan 2007 Posts: 8 New Guy | | New Guy Joined: Jan 2007 Posts: 8 | I have 2 gas tanks for the 55 suburban. One was hit pretty hard in the front and has been patched. The other one does not leak, but has a couple of dents on the bottom where it bottomed out on something. Does anyone have an idea what these would be worth? Is this the correct place to ask that? | | | | | Joined: Nov 2011 Posts: 14 New Guy | | New Guy Joined: Nov 2011 Posts: 14 | Broke down and bought a stainless tank that mounts at the rear of the frame. A bit pricey but one less thing to worry about. | | |
