| | | Forums66 Topics128,196 Posts1,057,388 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 33 New Guy | | New Guy Joined: Jan 2012 Posts: 33 | Just picked a used radiator and I want to clean it up right before I put it in my '64. Yes, I'd have rather bought a new one ... but couldn't afford it and this will be my sole daily driver in a few weeks. Thing is, there's a bunch of red spray paint across the fins on one side (see pic). The other side looks good. Wondering if the paint will even effect the performance ... Of course, I don't want to damage the fins. I've read that oven cleaner can work well, and that a caustic soda dip works too. Any idea on what that should cost? Funds are tight and I'm not going for a perfect restore here, just want it to function well. Any tips on cleaning (inside and out), the paint issue, and on a good install would be appreciated. Radiator - side with paint The better side ... but still some bent fins
'64 C10 1/2 ton fleetside
| | | | | Joined: Apr 2008 Posts: 64 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 64 | Have used a can of spray brake cleaner to remove paint on small items. The cheap brake cleaner form chain stores works well for this. If its cheap paint it comes right off, good paint takes a little longer. My only concern would be if it would damage anything on the radiator solder joints or fin material. Good luck. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Take it to the car wash and soap it good then rinse at the highest pressure setting.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | How about regular paint stripper and a bristle brush-make sure to protect your eyes. There are combs for fixing fins, however, just set the radiator flat while you watch your favorite TV program and get to it w/ the proper size screwdriver or other tool on the fins.
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Dont even bother removing the red paint. Clean it up real well with soap, water, soft brush or whatever and paint right over the red. I would be afraid that if you tried to remove the existing paint, you will make it worse. If you want to try anyway, oven cleaner is an affective and easy to use paint remover. | | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | i would just pressure wash and paint with a rattle can. radiator paint would be better if available. as far as straightening the fins. there isnt much from what i saw i wouldnt worry about them unless your a type a personality and just have to be perfect.
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Oven cleaner, then the "engine degreaser" option at your local coin car wash will do a good job of eliminating what's there. If you want to repaint it use flat, not gloss paint, and spray at about a 45 degree angle so only the edge of the fins gets painted. The fins in the middle need to be left unpainted for the best heat transfer. That's how we did it when I worked part-time at a radiator shop. Jerry
| | | | | Joined: Jan 2012 Posts: 33 New Guy | | New Guy Joined: Jan 2012 Posts: 33 | This is all really great ... thanks guys! A simple wash and radiator spray can coat it is!
| | | | | Joined: Sep 2010 Posts: 1,723 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,723 | Brake fluid will remove the paint without any damage to the radiator. Pour it on the paint, let it sit, then rinse off. Clean with a degreaser. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....if you use a pressure washer be warned how close you get to it......its be like aiming a high pressure garden hose at the fins on your house a/c unit. Your now warned!!
I like the idea of just shooting some paint over and moooving on. | | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Might be a good idea to drop it off at a radiator shop, have them test it, clean it and paint it. If there are no leaks, it should not be much for a test and cleaning....
| | | | | Joined: Feb 2000 Posts: 5,243 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,243 | A good wire brush with straight wires works really good for straightening fins, just brush it like you would a dog!
Hear is a second warning about high pressure and fins, stay back and spray straight down on them.
To clean the inside on the cheap, fill with hot water and radiator flush once you cap the ends off, slosh it around and rinse out. You can get the worst of the crude out and make it useable.
For paint, buy the $.99 flat black from you local hardware store, it covers with out a lot of build up.
Joe
