7 members (Hotrod Lincoln, Oswald, Hugh63c10, TUTS 59, Goach2, cmayna, 52Carl),
140
Mod | | | Forums66 Topics128,204 Posts1,057,294 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Welcome to the Stovebolt1  Nice truck, what do you haul? Mike B  | | | | | Joined: Jan 2012 Posts: 21 New Guy | | New Guy Joined: Jan 2012 Posts: 21 | Thanks for the welcome,You have some nice trucks,I will haul my 55 chevy to some car shows,and some projects I pick up here and there. | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Original 2 speed rear or did you change it ? My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Nov 2009 Posts: 73 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 73 | I like your truck. How fast will it cruise at. I have a 57 lcf that I want to put a rollback on. Welcome. | | | | | Joined: Jan 2012 Posts: 21 New Guy | | New Guy Joined: Jan 2012 Posts: 21 | It still has the 2 speed in it Original 2 speed rear or did you change it ? | | | | | Joined: Jan 2012 Posts: 21 New Guy | | New Guy Joined: Jan 2012 Posts: 21 | I havent had it on the road yet because of the brakes but based on what I have read on here I think 50-60 mph.Your truck would cool to see as a rollback I like your truck. How fast will it cruise at. I have a 57 lcf that I want to put a rollback on. Welcome. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Nice truck. I don't have a deck on mine yet, and I was thinking beavertail.
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Feb 2007 Posts: 9 New Guy | | New Guy Joined: Feb 2007 Posts: 9 | nice truck is it a 6400 or 6500? | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | The 2-speed in the '57 has a high gear ratio of 6.40:1 (low is 8.72:1). If you have 9.00x22.5 tires they are about 35" tall so your speeds will be as follows; at 2000 rpm = 32 mph at 3000 rpm = 48 mph at 4000 rpm = 65 mph If you have 10.00x22.5 tires they are about 39" tall so your speeds will be as follows; at 2000 rpm = 36 mph at 3000 rpm = 54 mph at 4000 rpm = 72 mph This calculater doesn't care how many cylinders or how much HP you have, it's all about RPM. My 1956 Tow Truck with a 350 sbc and a 2-speed runs 65 mph all day long. Hope this helps. Mike B  | | | | | Joined: Jan 2012 Posts: 21 New Guy | | New Guy Joined: Jan 2012 Posts: 21 | Your truck looks like its ready for the beavertail..nice truck.. Nice truck. I don't have a deck on mine yet, and I was thinking beavertail. | | | | | Joined: Jan 2012 Posts: 21 New Guy | | New Guy Joined: Jan 2012 Posts: 21 | Thanks... its a 6400 nice truck is it a 6400 or 6500? | | | | | Joined: Jan 2012 Posts: 21 New Guy | | New Guy Joined: Jan 2012 Posts: 21 | Thanks Mike that helps alot,Good to know that I can cruise. The 2-speed in the '57 has a high gear ratio of 6.40:1 (low is 8.72:1). If you have 9.00x22.5 tires they are about 35" tall so your speeds will be as follows; at 2000 rpm = 32 mph at 3000 rpm = 48 mph at 4000 rpm = 65 mph If you have 10.00x22.5 tires they are about 39" tall so your speeds will be as follows; at 2000 rpm = 36 mph at 3000 rpm = 54 mph at 4000 rpm = 72 mph This calculater doesn't care how many cylinders or how much HP you have, it's all about RPM. My 1956 Tow Truck with a 350 sbc and a 2-speed runs 65 mph all day long. Hope this helps. Mike B  | | | | | Joined: Nov 2009 Posts: 73 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 73 | Thanks for the chart Mike, I assume you have 10:00s on your 56 tow truck and that you are running about 3500 rpm at 65 mph. A little off subject but did you ever visit that big salvage yard and what were the results? | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Yes, I run 10.00x22.5's on my tow truck. I've been to a lot of junk yards in the past 8 weeks. I haven't been back to Greens in NC (was there 5-6 years ago). I didn't see any LCF trucks. I did score (2) SM-420 PTO's, an accessory Hi Tone horn for the 1955-56 trucks and a genuine Budd lug wrench. I also got the 55-59 Suburban gas tank wedges I needed to hang that tank on my '56 3100 pickup project. Mike B  | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | This is what someone recently said about Green's on the ATHS site, "all of the old stuff at greens is gone... cleaned up all the yards just got one site still operating with late model stuff in it....".
| | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | I'd like to see the picture!!!!! Thanks
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | The link worked for me on the second try... Mike B  | | | | | Joined: Jan 2012 Posts: 21 New Guy | | New Guy Joined: Jan 2012 Posts: 21 | sorry guys somehow I had it set up for private view,It should work fine now.Those pics are when I first picked it up, I have done a few things to the truck since,I will have to get some new pics up..
Dave | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | 57chevy2ton! WELCOME!! "Tater's got a younger brother!! I like the chrome bumper and mirrors! my grille and mirrors are beige,and now I have the cab lights installed.but that shade of maroon has got to be about as close as you can get,without goin' to a paint store! Check-out my pic's and video's in "Photobucket"! thanks for joining!! | | | | | Joined: Jan 2012 Posts: 21 New Guy | | New Guy Joined: Jan 2012 Posts: 21 | Thanks for the welcome,Your truck and mine do look like brothers!! Nice truck!!! 57chevy2ton! WELCOME!! "Tater's got a younger brother!! I like the chrome bumper and mirrors! my grille and mirrors are beige,and now I have the cab lights installed.but that shade of maroon has got to be about as close as you can get,without goin' to a paint store! Check-out my pic's and video's in "Photobucket"! thanks for joining!! | | |
