1 members (MikeE),
70
Mod | | | Forums66 Topics128,031 Posts1,055,436 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Back about March 2011 I put a new power steering pump on my panel as I put it all together. I started the panel, drove it up and down the road and then parked it in my shop until August 2011. At that time I took it to my nephews to put in the wiring harness. Its been there in his shop since. THEN....about 4 or 5 weeks ago ALL the power steering fluid drained out of it. Well, last week I poured the reservoir full and then watched it for an hour. No drip what so ever. After 5 days still no drip. All that to ask how do you explain that. It was a new pump, I put the "back plug" in with new O'rings and used new hoses ect. What gives that it leaked once but hasn't since? Your thoughts. | | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | My uneducated guess is you just filled the reservoir. Did you start the truck and turn the steering to load the system? Roy | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | Did the fluid puddle on the floor, or just sort of disappear? I've seen a pump reservoir overflow if the steering gear was turned to near the limits of its travel with the engine off, like when pushing a car in and out of the shop. Jerry
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Yes, I had "purged" the system back when I put it on and had driven it up and down the road, parked it in my shop and continued the restoration. No leaks what so ever. After trailering it to my nephews it sat in his shop for a while and no leak....until a 4 or 5 weeks ago.
Jerry, it puddled on the floor right under it. HOWEVER, you may be onto something but not sure...... a week or so before that I had pulled the tie rod ends off and put on the new modern type....BUT as I think about it I did NOT turn the wheels. I simply took the bolts off the steering arms and took the tie rods and steering arms out together and then put them back on without turning the wheels. (thought for a minute we had it,Jerry.
I THOUGHT maybe it was just cold and the seals were some what dry due to not being driven very much at all. But, my nephews shop, while it gets cold, probably never got below 40 degrees this winter.....but it maybe the coldness, then the heat being on had some cause and effect on it. I'm telling you guys, it just don't make sense and I talked to my nephew tonight and it still has not leaked!!
It had to come from the fill spout, the BIG nut screwed into the back of the reservoir, the "reducer" which screwed into the big nut, or where the High pressure line screwed into the "reducer" fitting. I will bet my last quarter it did not come from the front seal/shaft.
I'm still lost!
| | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Alvin,,,,Go out and kick the cat. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Alvin,,,,Go out and kick the cat. Marty, the poor cat is all bruised up and I'm having pity on him till he heals and can fight back  ....the more I think about this problem do you think it could be the rubber O'ring that goes in ahead of the "big bolt" could be "swelling and shrinking"?? ....but only once?? Jerry,come back, what you think? | | | | | Joined: Jun 2011 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 117 | Clearly your truck was abducted by Space Aliens. They sedated it and took it to thir mother ship where they inserted a power steering pump probe to see what they could learn. Expecting to find a limitless supply of Fanta soda (which aliens love by the way), they sadly found none and so returned the power steering fluid and your truck to its parking space. Your truck awoke in a drunken haze wondering if it had drempt the whole thing and feeling a bit queesey. Your truck subsequently vomited its power steering fluid all over the floor and has been too embarrassed to say anything to you since.
Just line every last square inch of the outside of your truck with tinfoil and it won't happen again.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Hey Alvin...refresh my memory on the pump and rack setup you have. Also, was puddle directly under pump or could leak be in rack seal ?
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bruce, its still a straight axle with power steering. I'm running a small block with the V6 brackets/serpentine belt. The pump is a NEW pump and the steering box is a remanufactured 76 pickup saginaw box. The leak was directly under it so it HAD to drip from the front seal....or the bolt/fiting/hose where it goes into the back of the pump. I just talked to my nephew tonight and its still not leaked a drop since I filled it back up. I will pick the panel up Thursday and bring it back to my shop. So, after running it some, putting it on and off the trailer, I'll see what happens when I park it in my shop where I can watch it everyday!! It just plain puzzles me. Bruce, here is a couple pics.. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/picsforphotobucket031.jpghttp://i140.photobucket.com/albums/r19/LutherParris/52Panel/grillerearend006.jpgRingleader, you may be on to something about the aliens. My wife was born in Roswell, New Mexico (really) and her kin folks are PO'd that I won't let her come home.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Clearly your truck was abducted by Space Aliens.Expecting to find a limitless supply of Fanta soda (which aliens love by the way), they sadly found none and so returned the power steering fluid and your truck to its parking space. Ringleader, the aliens obviously don't know Alvin,he's a Pepsi guy! Joking apart,Alvin I hope you get to the bottom of the problem soon! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I had the seals on the rack go bad three times in a row and lost all fluid. one only lasted 15 mins of idling. replace the reducer for a new one from jegs and have been driving it for 3 years with no problems.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
