| | | Forums66 Topics128,107 Posts1,056,221 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | Well with all this warm weather here in Arkansas I now have my top painted white. THe interior is next cant wait. Also I am going to replace boards in the bed floor do I have to have the bed off or can I do this with the bed on? | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | Not that it makes big difference, but what year is your truck? Fleet or step side? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The bed wood can be replaced with the bed, still on the frame. | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | The truck is a 65 fleetside swb | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Here is how we did the last one. Bed assembly | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | Thanks for the pictures My idea was to move the bed back a few feet then paint the back of the cab and the front of the bed then put the bed back and replace the floor with it on the truck. I only have so much room in my shop or I would take the bed completely off | | | | | Joined: Oct 2011 Posts: 117 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 117 | | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Hate to admit how mine was done. My 62 had a steel bed and I had to cut a hole in it for the differental to go thru when the truck was drppped the max thru the notched frame. Ibuilt the new floor out of the truck making it 2 inched higher to fix the diff. hole. I then just slid it in and bolted it down with 4 bolts. If I want to refinish it I will just take it back out. No one has noticed the bead being a little higher. It looks perfect if I do say so
