4 members (Otto Skorzeny, mk72, 55shaker, 1 invisible), 77 guests, and 1 robot.
Topics128,022
Posts1,055,387
Members48,422
#829488 02/25/2012 1:20 AM
7
7 Offline
Well with all this warm weather here in Arkansas I now have my top painted white. THe interior is next cant wait. Also I am going to replace boards in the bed floor do I have to have the bed off or can I do this with the bed on?
Not that it makes big difference, but what year is your truck? Fleet or step side?
Lugnutz #829511 02/25/2012 2:46 AM
The bed wood can be replaced with the bed, still on the frame.
7
7 Offline
The truck is a 65 fleetside swb
79broncoowner #829880 02/26/2012 11:19 AM
Here is how we did the last one.
Bed assembly
7
7 Offline
Thanks for the pictures My idea was to move the bed back a few feet then paint the back of the cab and the front of the bed then put the bed back and replace the floor with it on the truck. I only have so much room in my shop or I would take the bed completely off
7
7 Offline
Hate to admit how mine was done. My 62 had a steel bed and I had to cut a hole in it for the differental to go thru when the truck was drppped the max thru the notched frame. Ibuilt the new floor out of the truck making it 2 inched higher to fix the diff. hole. I then just slid it in and bolted it down with 4 bolts. If I want to refinish it I will just take it back out. No one has noticed the bead being a little higher. It looks perfect if I do say so
