4 members (MickeyP, Lostbuthaulinass, Wally / Montana, 1 invisible), 122 guests, and 3 robots.
Topics128,050
Posts1,055,753
#828 08/15/2002 12:32 AM
I am finally starting to put my engine back together and was checking everything out when I noticed that the Connecting rod bearings did not seem to fit into the conncting rod or the end cap. Is it common for these to sit high in the connecting rod until torqued down? When I place them on the connecting rod and end cap and look at it from the side, it looks like a little smile smile with between an 1/8 of an inch and a 1/16 of an inch between the two surfaces. What do you think? I dont want to ruin this before I get started.
Thanks for the help.
TOm
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
#829 08/15/2002 1:33 AM
Tom, usually you have to push them down to seat them in the cap and rod. You should be able to do this easily by hand. Also you should torque them with plasti-guage to check tolerances before final assembly and put some sort of break in lubricant on before running.
Good Luck
John....38 Chevrolet Panel Delivery
http://community.webshots.com/user/tobytailford
