6 members (Gdads51, Greg_H, Wayne67vert, Napco Man, moparguy, carbking), 65 guests, and 7 robots.
Topics128,187
Posts1,057,211
Members48,465
When I pull the wheels for new rubber, I want to replace the wheel cylinders. I believe there are two sizes, 1 1/2, and 1 1/4. Without disassembly, does anyone know what size they would be? It's a dump, but don't want to assume the larger.
3B Offline
Hy abxtc, according to my GM parts book all the trucks larger than one ton use the same 1 1/2" rear wheel cylinder. Raybestos p/n WC3677 $64.79 at RockAuto, hope that helps.
Rock auto also has the rebuild kits WK8 and WK37. Got a master cylinder at local parts house Don't recall the part number.front wheel cylinders are 1 1/4"
You also could have the cylinders re-sleeved, which is usually cheaper especially if these are rare and difficult to find.
best of luck
1946 1/2-Ton Chevy
The raybestos wk37 included new pistons for rear something lacking in last repair kit I got from Jim Carter. The wk8 for front did not include pistons
Wow! Thanks again, guys!
Consensus is:
1 1/4 front cylinder
1 1/2 rear cylinder WC3677
Tom
Hi all! Replaced the wheel cylinder yesterday,I going to have so much FUN working on this beast!
Thanks for the pointers to get me started.
Tom
