0 members (),
144
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | When I pull the wheels for new rubber, I want to replace the wheel cylinders. I believe there are two sizes, 1 1/2, and 1 1/4. Without disassembly, does anyone know what size they would be? It's a dump, but don't want to assume the larger. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy abxtc, according to my GM parts book all the trucks larger than one ton use the same 1 1/2" rear wheel cylinder. Raybestos p/n WC3677 $64.79 at RockAuto, hope that helps. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Rock auto also has the rebuild kits WK8 and WK37. Got a master cylinder at local parts house Don't recall the part number.front wheel cylinders are 1 1/4"
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | You also could have the cylinders re-sleeved, which is usually cheaper especially if these are rare and difficult to find. best of luck | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | The raybestos wk37 included new pistons for rear something lacking in last repair kit I got from Jim Carter. The wk8 for front did not include pistons | | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Wow! Thanks again, guys! Consensus is: 1 1/4 front cylinder 1 1/2 rear cylinder WC3677
Tom | | | | | Joined: Feb 2012 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 61 | Hi all! Replaced the wheel cylinder yesterday,I going to have so much FUN working on this beast!
Thanks for the pointers to get me started. Tom | | |
