1 members (Truckrolet), 156 guests, and 1 robot.
Topics128,115
Posts1,056,291
Members48,439
#82563 09/04/2007 11:55 PM
I just bought a 48 Chevy Fleetmaster to build me a street rod out of. This is my first car from that era. I noticed the six lug wheels and wondered if the drivetrain would be the same or simular to the trucks of the same vintage? Obviously, it's a 3 speed torque tube set up, but what's the chances it's the same length as the trucks?
The front clip and drivetrain are getting replaced on this car so if anyone can use them let me know, I'll have them out in a few weeks. It came with a 1955 235 engine too. That's going to need to find a new home also,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I seem to recall that originally the cars had a bit more HP. My 53' 216 truck engine was only about 96 HP or near that but the cars were around 112 or so and even more with the 235 and PG. Other than that I suspect that with a 3 speed tranny the drivelines were the same on the 1/2 tons trucks. However the rear ends were different and the cars had a higher gear ratio.
Someone here will know for sure.
Going to offer up that old inline huh' and replace it with one of those bent motors? Shame, shame...a pox upon your toolbox! You do understand that your monthly dues here will triple and you'll need a special password to enter if you do the "V" thing, don't you? :p
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
The '50 and up powerglide cars had 3.55 gears, but if you wanted to keep the 6 lug pattern for swapping into a truck you had to use '48 or earlier axles and housing with the 3.55 center section.
There is a tech tip on this. It only applies to '46 or older 1/2 ton.
Steve
'49 3800
'52 3600
'57 3100
Quote
Actually, the engine is already out and I tore into it already. There's alot of cancer to fix and I would rather weld stuff up than restore it, if you know what I mean. This car isn't in good enough shape to spend that kind of time on. Besides, have you looked at my list of trucks, or should I say partial list? I think I've paid my dues, LOL. I got bit by the street rod bug and thought I would save one that shouldn't be over thrashing a restorable one,
Scott
I'll work on posting a picture soon
OK, here it is
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
Somebody e-mailed me about this things suspension. Sorry, but I can't find your contact info. Can you send me another note, please?
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
Bump
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
