2 members (Hotrod Lincoln, Southerntruck), 109 guests, and 3 robots.
Topics128,142
Posts1,056,491
Members48,442
#824361 02/09/2012 4:55 AM
Does anyone have a picture of the rear brakes for 63 and up from a shop manual? I have all the parts but don't know how they go together. It has self adjusters.
Heh, heh...I always do one side at a time, so I can look at the other side to get it back together! wink
Sorry, I don't have any pic's, but I had to comment.
Good luck.
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Good advice.
The shoe with the biggest lining goes to the rear, adjuster goes on that shoe, linkage from adjuster goes onto the top post, then the rear spring goes from the shoe to the linkage. Put the lower spring on and install adjuster wheel so the wheel is under the adjuster arm. Install front shoe then the spring goes to the upper post,
some years and models may vary some but it should get the job done,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Not sure what happened to my post from yesterday, but here it is again. These photos from the 1960 Chevy Truck Shop Manual may offer some help. If there is any difference in 1963 it would be the addition of self-adjusters:
[IMG]http://img14.imageshack.us/img14/6731/13458107.jpg[/IMG]
[IMG]http://img32.imageshack.us/img32/761/613ch.jpg[/IMG]
[IMG]http://img703.imageshack.us/img703/646/614sr.jpg[/IMG]
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
