| | | Forums66 Topics128,141 Posts1,056,488 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | Does anyone have a picture of the rear brakes for 63 and up from a shop manual? I have all the parts but don't know how they go together. It has self adjusters. | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | Heh, heh...I always do one side at a time, so I can look at the other side to get it back together!  Sorry, I don't have any pic's, but I had to comment. Good luck. cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Dec 2010 Posts: 35 New Guy | | New Guy Joined: Dec 2010 Posts: 35 | | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The shoe with the biggest lining goes to the rear, adjuster goes on that shoe, linkage from adjuster goes onto the top post, then the rear spring goes from the shoe to the linkage. Put the lower spring on and install adjuster wheel so the wheel is under the adjuster arm. Install front shoe then the spring goes to the upper post, some years and models may vary some but it should get the job done, Scott | | |
