2 members (KEVINSKI, 1955 1 Series), 237 guests, and 2 robots.
Topics128,196
Posts1,057,395
Members48,471
Hi!
So I made pretty good progress on taking my stuck engine apart. I am down to the camshaft and crankshaft. Pulled both gears! Lifters are all out, head off etc
I can not get the cam shaft out!!! Removed the two screws on plate. Tried pipe wrench, but it won't hold! Was able to pry behind the plate a little bit, but little to no movement! Yes- sprayed the cam with lubricant/oil etc!
Any ideas?
Andy
Hi Andy,
Is the distributor out? It engages with the camshaft.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Don't forget to remove the fuel pump as well !
Tim
1951 3100 Chevrolet
If the cam is junk, like it sounds like it is, drill and tap a hole in the end of it and use a slide hammer puller to try to pull it out of the block. The simple way is to drive it out from the back, but the engine has to be removed to do that. It sounds like that engine needs to become a boat anchor and you needd to find a better-condition candidate for a rebuild.
Yes. Distributor and shaft and lower gears of fuel pump are out.
Jerry - got your e-mail. Thanks. I don't give up that easy smile I appreciate your thoughts though.
If the remains of the fiber gear are getting in the way, try burning it off. You should be able to sink the teeth of the pipe wrench into the steel collar.
1951 1 Ton Completed
