| | | Forums66 Topics128,195 Posts1,057,377 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | Hi! So I made pretty good progress on taking my stuck engine apart. I am down to the camshaft and crankshaft. Pulled both gears! Lifters are all out, head off etc I can not get the cam shaft out!!! Removed the two screws on plate. Tried pipe wrench, but it won't hold! Was able to pry behind the plate a little bit, but little to no movement! Yes- sprayed the cam with lubricant/oil etc! Any ideas? Thanks, Andy | | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Hi Andy, Is the distributor out? It engages with the camshaft. Samantha | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Don't forget to remove the fuel pump as well !
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2004 Posts: 29,885 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,885 | If the cam is junk, like it sounds like it is, drill and tap a hole in the end of it and use a slide hammer puller to try to pull it out of the block. The simple way is to drive it out from the back, but the engine has to be removed to do that. It sounds like that engine needs to become a boat anchor and you needd to find a better-condition candidate for a rebuild. Jerry
| | | | | Joined: Nov 2011 Posts: 196 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 196 | Yes. Distributor and shaft and lower gears of fuel pump are out. Jerry - got your e-mail. Thanks. I don't give up that easy  I appreciate your thoughts though. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If the remains of the fiber gear are getting in the way, try burning it off. You should be able to sink the teeth of the pipe wrench into the steel collar. | | |
