| | | Forums66 Topics128,178 Posts1,057,063 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 62 | Hey all.
Just picked up a 53 1-ton and was wondering what the pros and cons are when it comes to swapping its drive-line and rear end into my 51 1/2 ton project.
My main reason for wanting to do this it to go from the torque tube to the open drive-shaft.
Is this worth considering or is it not advisable? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Con- Top speed with a 1-ton rear end will be about 45 mph and the engine will be screaming. | | | | | Joined: Jan 2008 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 62 | Con- Top speed with a 1-ton rear end will be about 45 mph and the engine will be screaming. That's a pretty big con. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Your best bet would be using the 1 ton transmission, shorten the driveshaft and leave the rearend alone. Find a later model 1/2 ton rearend and swap it in. | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Or just replace the torque tube with the forward shaft/tube from the 1 ton and put a second shaft back to the axle, like the 3/4ton. You still need an open rear, so a new axle or weld the spring pivots and change the center section for a 55 or later one. If you don't need the new engine or trans, you can make the change at the u-joint ball. Another way to go open is just put in a T5.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Jan 2008 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 62 | Great advice guys, thanks! | | |
