0 members (), 61 guests, and 4 robots.
Topics128,179
Posts1,057,160
Members48,465
Hey all.
Just picked up a 53 1-ton and was wondering what the pros and cons are when it comes to swapping its drive-line and rear end into my 51 1/2 ton project.
My main reason for wanting to do this it to go from the torque tube to the open drive-shaft.
Is this worth considering or is it not advisable?
Dallas Huybregts
Sherwood Park, Alberta
1951 Chevrolet 1300
email
Photobucket
flickr
Con- Top speed with a 1-ton rear end will be about 45 mph and the engine will be screaming.
That's a pretty big con.
Dallas Huybregts
1951 Chevrolet 1300
email
Photobucket
flickr
Your best bet would be using the 1 ton transmission, shorten the driveshaft and leave the rearend alone. Find a later model 1/2 ton rearend and swap it in.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Or just replace the torque tube with the forward shaft/tube from the 1 ton and put a second shaft back to the axle, like the 3/4ton. You still need an open rear, so a new axle or weld the spring pivots and change the center section for a 55 or later one.
If you don't need the new engine or trans, you can make the change at the u-joint ball.
Another way to go open is just put in a T5.
Great advice guys, thanks!
Dallas Huybregts
1951 Chevrolet 1300
email
Photobucket
flickr
