0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Need help again...
We disassembled the 1957 axle and found all the bearings were Hyatt brand in various sizes.
I have searched the net for about 3 hours with no luck, trying to locate the right bearings to replace my Hyatt or1502 rear wheel bearings. The axle diameters at the bearing surface are around 1.88 inches. All of the searches I have done so far for replacement bearings have resulted in listings for bearings that are around 1.3 inches (Bore size).
Anyone else run into this issue? My original bearings were about 2.77 OD.
Thanks in advance.
Jim | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Any # on the bearing? If there is go to a FLAPS and they should be able to match them,by the # or by app.
Pete | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you should be able to go to NAPA and give them the application and get the right rear axle bearings, and if you give them the Hyatt OR1502 number they should be able to cross it - that is not OEM, which should be NATIONAL Part #RW607NR
Bill | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Fourbrads, the O.E.M. for 1957 1/2 ton rear axle/wheel bearings is 111121 which is Hyatt p/n C1502, outer race and rollers, same p/n for SKF, for Bower p/n R1502EL, hope that helps. | | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Thanks all, that helps quite a bit.
Just by pure stubbornness, I started seeing the R1502ELs and the like with similar ID and OD numbers, but you can never be sure. I'll go to NAPA soon and double-check.
I appreciate the great responses.
Jim | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Jim
With the numbers you gave me this morning I too landed on the TIMKEN R1502EL. I think thats the winner....
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Thanks SWEET,
That's what I'll get then.
Appreciate it. Will call you when the new toys are in.
Jim | | |
