8 members (Jon G, 68ironhead, GMCJammer51, baldeagle, dt235sd, panic, JW51, 1 invisible),
42
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | The PO replaced the engine in my 53 Burb with a 54 235. I rebuilt the carb last weekend and noticed someone had hogged out the bolt holes in the carb base. I just assumed they put the carb from the 216 on the 235, then it dawned on me that they had used the manifolds off the 216, and the carb for a 235. Now I'm wondering about if the head is wrong? The casting # is 3835913, can someone ID it for me? Thanks
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Just looked over on Inliners.org and see 3835913 for that head. May want to take another look. Good luck Jim | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | google the casting number and it will show that it is from a 1954-55 235. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Here are locations of casting codes. The date casting codes will help to ID the head and the block. | | |
