8 members (Bill Hanlon, Jon G, 55shaker, Otto Skorzeny, HandyAndy, UtahYork, DadsFirstPickup, Hotrod Lincoln), 78 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#821663 02/01/2012 12:09 AM
Y
Y Offline
The PO replaced the engine in my 53 Burb with a 54 235. I rebuilt the carb last weekend and noticed someone had hogged out the bolt holes in the carb base. I just assumed they put the carb from the 216 on the 235, then it dawned on me that they had used the manifolds off the 216, and the carb for a 235. Now I'm wondering about if the head is wrong? The casting # is 3835913, can someone ID it for me? Thanks
Yakimabowtie #821668 02/01/2012 12:23 AM
Just looked over on Inliners.org and see 3835913 for that head. May want to take another look.
Good luck
Jim
1946 1/2-Ton Chevy
JiMerit Boltr#43 #821682 02/01/2012 12:41 AM
google the casting number and it will show that it is from a 1954-55 235.
GMONIZ #821715 02/01/2012 1:38 AM
Here are locations of casting codes. The date casting codes will help to ID the head and the block.
