1 members (1 invisible), 105 guests, and 3 robots.
Topics128,089
Posts1,056,440
Members48,443
#821308 01/31/2012 12:46 AM
I am missing the lever/linkage for the cowl vent on my 40 chev 1/2t. Any place to see what it looks like? What years are the same?
Thanks.
Ex Hall Monitor
Ex Hall Monitor
They are all similar but how many years and models are interchangeable I don't know. If you don't already you might start checking ebay regularly. I see vent lever assemblies regularly.
Dexter, I know we are suppose to do our wheeling and dealing in by PM but this is not an offer to buy or sale..... I'm simply saying if a 52 AD style will work...then we can do the PM thing as I have one.
Thanks for the response. I hate to rely on Ebay since I have seen statements that 40-46 are the same and others say only 39 & 40 are the same. I am fairly sure that 47-53 are different since the cabs changed. I am inclined to believe that 39 & 40 are interchangeable, but would like confirmation before buying.
I have both a 40 and a 41 and the levers are a little different between the two. However, since the dash and cowl are the same, it is possible that the two may be interchangeable.
My toys:
'41 Chevy Model AL 3/4 Ton
'40 Chevy Model KD 3/4 Ton
Hinomoto 209N Tractor/Backhoe
Norwood LM2000 Sawmill
PJ 16' Trailer
and a Brand New Shop!
Be what you is, not what you ain't, 'cause when you is what you ain't, then you ain't what you is.
Thanks for the info. I have a part of the linkage that hooks to the vent. It is short and curved with some ripples along the curve with a hole drilled in the ends. I used to have a 50 and it had a flat bar with a slot in the end and was 90 deg.with a short flat bar attached to the vent. Parts claiming to be 40-46 look a lot like my 50 linkage, in my mind, which is not the most reliable place to draw from. HA.
