4 members (MickeyP, TUTS 59, Thom75, 1 invisible),
160
Mod | | | Forums66 Topics128,284 Posts1,058,531 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82108 08/27/2007 2:40 AM | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | I was just wondering if on a '66 fleetside if the steering shaft will separate from the column up near the firewall. I don't see where. I have it separated from the gearbox at the leather coupling area, but do I have to pull the steering wheel with the shaft attached all out? thanks for any help. sovagary
GS
#82109 08/27/2007 2:45 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Are you wanting to remove the column? If so, then the whole shaft has to come out with it. I think that the rag joint is the only separation point on those.
Bill Burmeister | | |
#82110 08/27/2007 2:46 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | From the ragjoint to the steering wheel is one solid shaft, Scott | | |
#82111 08/28/2007 2:29 AM | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Thanks. That's the way I will remove it.
GS
