Brrrr
place holder
2 members (Rich'sToys, UtahYork), 123 guests, and 1 robot.
Topics128,274
Posts1,058,430
Members48,489
#82108 08/27/2007 2:40 AM
I was just wondering if on a '66 fleetside if the steering shaft will separate from the column up near the firewall. I don't see where. I have it separated from the gearbox at the leather coupling area, but do I have to pull the steering wheel with the shaft attached all out?
thanks for any help.
sovagary
GS
Are you wanting to remove the column? If so, then the whole shaft has to come out with it. I think that the rag joint is the only separation point on those.
Bill Burmeister
From the ragjoint to the steering wheel is one solid shaft,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks. That's the way I will remove it.
GS
