1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 4 New Guy | | New Guy Joined: Nov 2006 Posts: 4 | I have a "49 Chevy 4400. Is the front hood emblem the same as the ones used on the 1/2 and 1 ton pick-up?
Oliver Shagnasty Beautancus NC | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I don't believe so. The 1/2 up to 1 ton had a differant size hood due to the larger front fenders. The 1 1/2 to and 2 ton had the same hood. I know in '54 the hood front emblem was a differant size. The hood side emblems are the same.
Bruce | | | | | Joined: Nov 2006 Posts: 4 New Guy | | New Guy Joined: Nov 2006 Posts: 4 | Thanks guys --- I was afraid of that.
Anyone happen to have one for a 4400. A pecan limb fell out of a tree and broke mine.
Oliver Shagnasty Beautancus NC | | | | | Joined: Nov 1995 Posts: 5,721 62401 | | 62401 Joined: Nov 1995 Posts: 5,721 | Oliver, For whatever it's worth, I never even thought about asking this question when I restored my '49 4400 and I just bought a repro hood emblem from American Classic (probably the same one Jim carter and the others have, too). It bolted right on and looked identical to the rusty dented one I removed from the hood. Here's some pictures of mine -- scroll down through it until you get to the shots of the finished hood. That's the same hood emblem everyone else orders for their little trucks and it appears to be a form/fit/function replacement. I can't speak to exact correctness or part numbers, though. All I can do is tell you it fit the hood seam and the bolt holes perfectly. Good luck, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Nov 2006 Posts: 4 New Guy | | New Guy Joined: Nov 2006 Posts: 4 | John, I had gotten down to the point of hitting the pay now button to order one from American Classic but, decided to check here first. If yours fit, that may be the way I go.
Did you use the same piece on the hood seam. If not, where did you get a new one?
Oliver Shagnasty | | | | | Joined: Nov 1995 Posts: 5,721 62401 | | 62401 Joined: Nov 1995 Posts: 5,721 | Oliver, Go ahead and order it -- if for some strange reason it doesn't fit, they'll take it back. On the hood seam, I didn't need to replace mine. If you need to replace yours, you'll need to find one from another hood, probably. They aren't available as replacement parts. A decent used hood (or just the seam piece) for an AD big bolt shouldn't be too hard to find -- put an ad in the Parts Wanted section and maybe one of the Western gang will send you one from their vast supply of pristine parts trucks they have out there  Good luck! If you have a hard time finding one, you can always come up here for the Stovebolt Homecoming and have the one on the Stovebolt HQ driveway ornament -- it may still be useable ...  John
