Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (TUTS 59, Otto Skorzeny, Steelonsteel, Many Winters), 134 guests, and 5 robots.
Topics128,282
Posts1,058,496
Members48,490
I have a "49 Chevy 4400. Is the front hood emblem the same as the ones used on the 1/2 and 1 ton pick-up?
Oliver Shagnasty
Beautancus NC
I don't believe so. The 1/2 up to 1 ton had a differant size hood due to the larger front fenders. The 1 1/2 to and 2 ton had the same hood. I know in '54 the hood front emblem was a differant size. The hood side emblems are the same.
Bruce
My Trucks
Stuff I Collect
Bruce is correct regarding there being at least two sizes of emblems. In the Master Parts Book there are three different part numbers for 47-53 front emblems.
The MPB lists:
#1 for COMM (Commercial 1/2 ton through 1 ton)?
#2 for D-D (Dubl-Duti, Forward-Control Chassis - used for non-GM Step Van) and UTIL (1.5 and 2 ton trucks)
#3 for COE
two different 1954 emblems (from an old article by Bob Adler)
The 1954 COE emblem was mounted an on special base, as is the earlier emblem on a COE.
Step Van - built on Dubli-Duti chassis
Thanks guys --- I was afraid of that.
Anyone happen to have one for a 4400. A pecan limb fell out of a tree and broke mine.
Oliver Shagnasty
Beautancus NC
24601
24601
Oliver,
For whatever it's worth, I never even thought about asking this question when I restored my '49 4400 and I just bought a repro hood emblem from American Classic (probably the same one Jim carter and the others have, too). It bolted right on and looked identical to the rusty dented one I removed from the hood.
Here's some pictures of mine -- scroll down through it until you get to the shots of the finished hood.
That's the same hood emblem everyone else orders for their little trucks and it appears to be a form/fit/function replacement. I can't speak to exact correctness or part numbers, though. All I can do is tell you it fit the hood seam and the bolt holes perfectly.
Good luck,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
John, I had gotten down to the point of hitting the pay now button to order one from American Classic but, decided to check here first. If yours fit, that may be the way I go.
Did you use the same piece on the hood seam. If not, where did you get a new one?
Oliver Shagnasty
24601
24601
Oliver,
Go ahead and order it -- if for some strange reason it doesn't fit, they'll take it back.
On the hood seam, I didn't need to replace mine. If you need to replace yours, you'll need to find one from another hood, probably. They aren't available as replacement parts. A decent used hood (or just the seam piece) for an AD big bolt shouldn't be too hard to find -- put an ad in the Parts Wanted section and maybe one of the Western gang will send you one from their vast supply of pristine parts trucks they have out there smile
Good luck!
If you have a hard time finding one, you can always come up here for the Stovebolt Homecoming and have the one on the Stovebolt HQ driveway ornament -- it may still be useable ...
smile
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
