4 members (KEVINSKI, Guitplayer, Samantha, lumbersawyer), 109 guests, and 1 robot.
Topics128,154
Posts1,056,855
Members48,456
I would like to hang the frame of my 57 1/2 ton from the rafters of my shop so I can prep it and paint it at a convenient height. It's already sandblasted. I've got the rafters braced for the load.
I thought I'd use several of the holes in one side of the frame and temporarily install eye bolts and then hang the frame with chain and hooks.
Would this method put any unusual strain on the frame and cause it to deform?
Am I missing any other problems with this method? Please let me know your thoughts or experience with this idea. I put it here instead of in the paint area because I thought more people would see it.
Larry
If you have all the cross-members still in place, I would think hanging it for a few weeks would not be a big deal.
1940 Chevy KC 1/2-Ton
Go for it
•1952 Chevrolet 3800 pickup
---All pictures---
It will not flex enough to permanently deform. Don't weld anything to it while it is hanging as it will be welded to a slightly flexed shape, not the same as when it is on its wheels.
Paint should be flexible enough to withstand the (very slight) change in shape when you bring it down... Powder coat might crack at rivet joints.
That is how I painted my 37s frame.
Okay then. I 've got to stop procrastinating and get to it. Thanks for the replies.
Larry
If it were that flimsy, I wouldnt use it as a frame!...haha
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
