1 members (Materman), 115 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#818228 01/21/2012 3:34 AM
Ok I'm just about ready to start replacing the rusted out part of the floor in my 52. How much of the floors sheet metal can you remove and still maintain the integrity of the cab? I purchased a right and left new floor.
Joe
jremig #818313 01/21/2012 2:49 PM
If your patch panels do not go as far as the corners u should be ok. Some left and right patch panels go from the front of the seat frame to approx. 6 inches up the angled surface headed to the firewall. Neither goes as far as any corner. Rocker side edge yes, but not a 'CORNER". That is where the strength would be, in the corners. If u are messin with any more than 1 corner at a time. I would do some bracing first.
'52 3100 "once a Marine, always a Marine!!
Panhead59 #818462 01/22/2012 12:10 AM
That is what I have. The new floor panels go from front of seat frame to half way up the toe kick and from the trans cover opening to where the door meets the edge.
jremig #818521 01/22/2012 3:06 AM
same as I used jremig. You should be fine but as always, measure twice and cut once!
