0 members (),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | Ok I'm just about ready to start replacing the rusted out part of the floor in my 52. How much of the floors sheet metal can you remove and still maintain the integrity of the cab? I purchased a right and left new floor.
Joe | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | If your patch panels do not go as far as the corners u should be ok. Some left and right patch panels go from the front of the seat frame to approx. 6 inches up the angled surface headed to the firewall. Neither goes as far as any corner. Rocker side edge yes, but not a 'CORNER". That is where the strength would be, in the corners. If u are messin with any more than 1 corner at a time. I would do some bracing first.
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | That is what I have. The new floor panels go from front of seat frame to half way up the toe kick and from the trans cover opening to where the door meets the edge.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | same as I used jremig. You should be fine but as always, measure twice and cut once! | | |
