3 members (Nick in Manitou, CuzzFuzz, Tronman), 115 guests, and 2 robots.
Topics128,080
Posts1,056,314
Members48,442
I bought a 71 GMC 3500 and "going through" the mechanicals to make it safe etc. Wanted to replce the front flexible brake line hoses. It has disc brakes. Was told the flex line for that truck has been discontinued for years. Called Classic Parts to ask if the 3/4 Chevy line would fit and he said the GMC did not have the same braking systems as Chevy. The line is not leaking so I am not out of a truck. Any sugestions on who to call to see if any are avaialble in the aftermarket. If not, what then....change the spindle and related parts over to a later model?
Riding in the Passing Lane
Napa catalog shows 36678 &36679 R&L for 71 GMC. It shows the same for Chev. They should be readily available.
1972 Chevy c10 Cheyenne Super
who told you they were discontinued. napa should have those.
Click!
Your not crazy. The only supplier of these lines I have found is through Jim Carters. I only saw them there once and not since. You can find a brake place to custom make the hose, but they don't use the rounded heads with the tab where the banjo bolt goes through. this may require you to take a grinder to the caliper for them to actually fit.
Maybe Jim Carter carries them again.
Jeff
My 1953 Chevrolet
1947.1 Gallery
