Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#812695 01/03/2012 3:19 AM
i am running a 250/6cyl eng.i am using a new 3 core radiator .i useing a manuel temp gauge,screwed in the side head.the gauge shows 210-225.at same time using atemp probe in raditor it shows 175.is this correct?also i am using a 15 elect fan
johnhull #812715 01/03/2012 4:47 AM
Find another guage to try.
Builder #812727 01/03/2012 5:08 AM
i should have told you that i bought anew one at tractor supply,same excact thing,,,,,,
johnhull #812731 01/03/2012 5:19 AM
the temp in the top of the rad will be the same as the temp near the thermostat, either your gauge or your 'probe' is inaccurate or your thermostat isn't opening .... what rating thermostat do you have? is it airlocked?
use an infrared laser type thermometer on the thermostat housing, the head where the sender probe is, and the lower rad hose
Flxible #817523 01/18/2012 9:53 PM
sorry to bring this up again,i am running a 180 thermostat.i am using two temp gauges.one in the thermostat housing,one in side of block.the one in thermo houseing is 175,the one at side of block 200.(this is a new gauge).also i am usinga18" truck fan.would you drive on the hi.way with these temps?thanks again...
johnhull #817535 01/18/2012 10:14 PM
the temp rating of the stat indicates what temperature it will open/close, if the reading near it is 175 it likely won't be opening all the way .... I'd skip the sender in the block, there is no factory info for the temp there, and I'd use an infrared digital thermometer to check the actual temp at various places, what 2 different dash gauges say can be correlated to that actual temp, especially the thermostat housing, top of the core, and bottom of the core - if there's a drop top to bottom of the rad of around 20 degrees things are working
