0 members (),
182
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,108 Posts1,056,228 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Hi guys,
My truck has been running excellent for the past year since I got it running...until last night, it started to make a pinging, or tapping, noise while driving. It progressively got louder and louder until I got it home, now it's parked until I can find the time to tinker with it to see what the issue is. It shows up very audibly if I put the truck under load, like going up a hill. Just idling, I don't hear it at all, even if I rev it. Definitely not a low end clunk, so I don't think its a bearing...it's a tapping, sounds like something small...definitely a metallic sound. My best guess is a stuck lifter, or my rocker arms need adjustment, but I don't really know, as I am still new to the hobby. Seeing how it's not a daily driver, I don't mind having to take apart the engine until I find what it is, but, was wondering if anyone had suggestions as to what to look out for when i take apart the engine.
The truck is a 61 by the way, with its original 235.
Thanks!
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | one thing to check (and not the only) is for a bent push rod ...pic... that would make more of a tapping noise | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | Valve train noises usually don't change with changes in engine load. If it is quieter when the oil is cold suspect rod bearing problems--and there is, when warmed up, usually a speed where it will be a chatter or rattle.This may be up around 1500-2000 RPM unloaded. At idle shorting out 1 plug after another may show a change in noise when the guilty cylinder is found. An exhaust leak where the manifold joins the head will give an almost tapping sound that will go away when you let up on the gas.It will probably be worse cold than hot because the gap usually closes up as the hot manifold grows. Again, valve noises usually don't change as the load changes.
Bob Taylor
| | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Ok...say that the problem is the connecting rod bearings. those can be changed without having to overhaul the block, right? Pull the pan off, take off the end caps, tap the upper bearing halves out, tap in new ones? | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | ...unless of course the crank or the block are scored. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | my truck sounded similar, but it turned out to be a leaky exhaust gasket where the manifold and pipe meet. (thats 2 with the same suggestion) I would go there long before I started tearing into the engine. I would do a lot of studying and get one of those mechanic stethascope things and do some listening around before I came to any hasty conclusions that involve tearing the engine down. But if you have an original 61 engine, there is a good possibility it needs rebuilt anyway. | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | I would think rod bearing noises are a thunk sound that you'd be able to recognize as the sound is deeper within the block. A tapping sound to me, points to slack in rocker arm activity (lack of oil, excessive slack). If exhaust, your ear should locate the sound to that side of the engine... if lifter/push rod, to the top. If it were me, I'd first pull the valve cover and investigtate the action... and go from there. Jerry | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Thanks for the advice guys. I think I will start with checking out the guts under the valve cover and inspecting the exhaust. Now if it would only warm up so I could work on it! -28 degrees celsius here in Calgary today! The truck is in a garage but there's no heat! | | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | An easy and cheap way to determine where noises are coming from in an engine is to use a 1/2 inch long extension. Put one end to the engine and cup the other with your hand to your ear. You'd be surprised at what you can hear.
1939 Chevrolet Stake Truck
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | As rickmg says, you can isolate an area of noise quite easily just by listening to various points around the engine. My favorite listening stick is a long screwdriver, handle to my ear, works great. Manifold gaskets can be difficult to seal on these motors. I've found intake leaks by spraying Berrymans Chemtool around manifold with engine running, if she speeds up you've lost your intake seal.
Best of luck. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Sounds like what we used to call "spark knock" (detonation). Where did you fill up last? Could be bad gas but I'd also check your point gap and timing. If it only shows up under a load this sounds like it could be the culprit. Also check your vacuum advance unit to see that it's operating freely and not sticking. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That was my first thought, spark knock.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Detonation...yeah I never thought of that! I filled it up at a Safeway gas station last, but I've taken it there before. I reset the timing about a year ago, but I've never checked the points in as long as I've had the truck. I don't know anything about points...what should I be checking for? What do I do? And the vacuum advance, that's in the distributor isn't it? The whole distributor moves when the engine is revved.
Yeah that noise shows up only under load, not when idling or revved. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Have a look at the shop manual, under "Tune-up" or something like that. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | If the distributor moves back and forth you're good to go on that one. Check to see if the distributor locking bolt is tight, it should only go so far and then right back. To check the points, pop the cap off the distributor, and turn the engine over by hand until the rubbing block pushes the points open to the widest point. Points should be nice and clean, no pitting, corrosion, or other nasties. A .016" feeler should fit in the gap. If not, loosen the lock screw and adjust them so it does. After that, recheck the timing.
| | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Thanks Waldo, sounds easy as pie. I have the shop manual too, somewhere. Will have to find it and do some reading. | | | | | Joined: Dec 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 35 | FYI - I had a brassy sound and or knocking a bit, nothing like a bad rod , while under load or crusing around 50. I redid the timing, adjusted the valves about 4 times to be certain( in case slop in rockers as ealier comment and added Lucus oil addative , heavy oil 50% and the noise is gone. I don't know!! Just my 2 cents.
'57 3200
| | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Ok, so I finally tackled the truck tonight because it has warmed up. I redid the timing, it was barely out, that didn't solve the pinging. What I did find however was a bent pushrod. Do you guys think that could be it? I'm gonna replace the rods anyway, it's too bent to keep driving it. And also, what causes a rod to bend like that? Should I replace the lifters too, or is that not necessary? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Do you guys think that could be it? My bent rod sounded like THIS It bent after the tuuck sat for a while. Valve stuck I only replaced the bad rod and reset lash. Someone else may advise on weather you should replace lifter or not. I did not Good Luck | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Mine sounds normal when idling. Doesn't sound anything like that, but, my bent rod was doing the circle dance like yours was.:D I've been driving it for over a year and it only started doing this a week ago. My truck has sat for a very long time though, prior to me driving it. It's had about 3000 miles or so put on it since 1987, so it was used very little since. The valve springs and rocker arms are all moving as they should though, so I dont think one of my valves is stuck...at least I hope not. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Excellent way of describing and engine noise Gus a big thumbs up to ya. All to often we here people try to describe a noise by the written word and we all have different interpretations of what it might sound like. It’s like trying to describe a color or smell. One of our members was asking about a loose heat riser valve yesterday. How loose is loose and how would you describe the problem? Some years ago I brought up the idea that someone looking for a project should make an audio/video of engine sounds. I think a CD would really sell if it was well done. Take a good engine and maladjusted the valves or replace a good piston or rod or main bearing with a bad one to show what these sounded like. A rod knock or piston slap or loose wrist pin or clunking main bearings are hard to describe to most people but a good audio of them would really clear the air. A good example is the previously mentioned loose heat riser, if its just a little puffing from the shaft then its no problem and an audio/video of that would say it with one look & listen.
Thanks Gus, I wish I knew how to manipulate those videos, I’d be using them in my replies for sure.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Denny, I like the audio/video idea of engine sounds. Brings back memories of my first father in law. Old guy raised the the mountains of NC, no education, worked on cars all his life untill the age of electonics. He just didn't know how to do it. He could dignose a problem just by listening to the sound. He worked for a small Chrysler dealer in Louisa Va and the owner had a collection of old cars to rival the best of collections. Mr Pettit, WAC Pettit III, had everything from 1928 Rolls to the plain old Plymounth sedans. That old man could work on all of them with confidence and all through the sound. I miss that old man.Larry
58 gmc 100 with 350 sbc
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks for your comments Denny.Im a noob at all this, so the videos help me quite a bit. Picasa, Flickr, and photo bucket allow uploading of videos, and are free. BigTonka schooled me on loading videos to picasa Adam61 let us know if it improves after you replace the rod. I picked up rods for my 235 at NAPA. Here is how it sounded after I replaced the rod. ..click... You still may have other issues described earlier in the thread. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Gus -
Thanks for posting the videos and before-and-after sounds.
> I see that you cut out the top of a valve cover to contain the oil while checking and adjusting your valves. How much splash and dribble do you think that it will make in my engine bay if I don't use a similar baffle when adjusting and checking the movement of my valves? I'm reluctant to chop off the top of my spare valve cover for what will probably be a one-time job. FYI - I will clean the engine afterwards to prep for painting the engine.
> Also - did you torque the head before adjusting the valves, as directed in the Shop Manual? The head and gasket are good on my truck. Not looking to cause a problem if none exists.
It's probably evident that I've never adjusted solid lifter valves before. And only played with hydrolic lifter valves once - and that was on a 327 in 1965.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | > I see that you cut out the top of a valve cover to contain the oil while checking and adjusting your valves. I purchased a used cover at a swap meet for a few bucks, that’s why I had no problem cutting it up. There is not much oil dripping off the rockers at idle, you may only have to dam the rear near the firewall if you choose not to use an open cover. > Also - did you torque the head before adjusting the valves, A while back I found a small coolant leak dripping off the head near the firewall. I posted a question in the forum and It was suggested by Pre '68 Dave to try re-torqueing the head bolts. I did the re-torque and the leak stopped. Then I re-adjusted valves the after the re-torque, again suggested by Pre '68 Dave | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Lonnie, I adjust my valves while with the engine running all the time, as Gus says, there is just a dribble out of the rockers at idle. I don't really have much trouble with getting oil down the side of the head. Only problem you'll have retorqing the head will be that dang center head bolt.
Denny G
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Thanks for the info, guys.
Hope to try my hand at adjusting valves in the next couple of weeks ... after water pump and motor mounts.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Do any of you know if other Chevy inline six engines, or even the V8 engines, use the same pushrods as a 235? Napa can't get them for me...I'm gonna try a few other places, but was wondering in case I have to get them from a wrecking yard. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Napa should have been able to get them. The part number is SEP RP3020.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | I called Napa today, they said they have a part listing but nowhere to order them from because it seems nobody has them. He's gonna take it to management and give me a call tomorrow. And we don't have Orielly in Canada. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | try Rock Auto online also They list the RP number referenced by LONGBOX55 deleted my earlier post
| | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Well, I finally got the new pushrods, and I installed them today, replacing the bent one and all the rest. I put it all back together and took it for a spin down the street. No difference. I still have the pinging noise. I also have noticed that while cranking the engine to start it, I hear almost what sounds like air being blown through a small opening somewhere, like it's in one of the cylinders or something. I can hear this same sound when taking off from a stop. Standing by the exhaust pipe while the engine is running, I've noticed that it now has a miss. It used to idle with a really steady hum, now it chugs sorta. My best guess is I have a burned out valve. I really hope I'm not right. Anyone else have anything to throw at this? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Same symptoms a few months ago had too replace push rod guides was not done when engine was over hauled, their mistake or oversight.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Go back and check your valves one more time. You may have missed one. It wouldn't be the first time thats happened.Larry
| | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | What do you mean "check the valves"? I haven't adjusted the valve lash yet...think that might be it? That air blowing noise and the miss in the idle is pretty obvious, and it didn't do that at all before. Maybe one valve is set too tight and never really closing? I'm learning still, kinda flying by the seat of my pants, ha ha
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Sounds like the cart getting ahead of the horse. Why would you take it for a drive and not check and adjust the valves first? Repairing anything from a old truck to putting together kids toys you have to start with #1 and then follow the steps. If you work through everything needed to make a truck run you will know what to expect when you get to running and driving it. You need to make sure you have good spark, good fuel supply, good compression. Turn your engine over by hand and watch to make sure you don't have a valve sticking, get the valves set .002 tighter than the hot spec. Then oil the cylinders and do a compression test. Make sure you have good spark. Then get the engine up on #1 and make sure the rotor is pointing at the #1 terminal on the distributor cap. Then you can begin to make an informed decision as to your next step. Don | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Sorry, my mistake. It never hurts to back track and check over your work. I thought you had, still worth a check, espceially the one where you replaced the pushrod.Larry
| | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Ok thanks
About the compression test, how do I do that? Do I pull all the plug wires off and thread in a guage in a cylinder at a time, and crank the engine to get a reading? I'm assuming I will need a partner to crank the engine so I can read the guage. Never done this before.
| | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | Essentially that's all you do. Yoo don't NEED help really oh just end up running back and forth from the engine compartment to the cab. Look at it as exercise! Screw the fitting into the spark plug hole, set the gauge on top of the valve cover, and crank the engine. 7-10 revolutions should be plenty, it really doesn't matter as long as you do it the same per cylinder. The manual says 130psi. Is minimum. A compression test reall will only tell you if you have compression. It won't tell you were you're losing compression from. A leak down tester will be more telling.
Before you do anything adjust your valves. If you are doing it cold add .004 to your measurements. I= .006 hot add .004 cold so .010 X= .016 hot add .004 cold so .020
The expansion of the valve train is our enemy here you don't want any valves hanging open. Re adjust them to spec after you've gotten it hot.. Not warm.
My .02
Jeremy | | | | | Joined: Dec 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 35 | I had a similiar noise and due to a gas leak in the intake manifold, cleaned the needle valve, adjusted the float, changed the gasket and the sound is gone as is the gas leak. Perhaps an exhaust leak may be the problem,just my 2 cents.
'57 3200
