Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (tclederman, rfs56trk, Woogeroo, Peggy M, 1 invisible), 48 guests, and 6 robots.
Topics128,010
Posts1,055,299
Members48,419
#816416 01/15/2012 4:58 AM
Ok, here's an easy one: Should the zirk fittings on my tie-rod ends point towards the front or the rear of the truck? I doubt that I'll ever have to grease them again but would like to do 'em right.
Same question on the locking brackets that lock the ends into the tie-rod: Should the nut be facing the front or rear? Want to make it easy on my alignment guy.
Thanks - Bruce
1 Offline
I would point the zirks in whatever direction it makes it EASY for the guy running the grease gun.
I would leave them pointing whichever direction they are when I got them tight. grin
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I think that deserves a rim-shot! So I found a picture from when I pulled the truck apart, it looks like the zirk fitting is on the front side of the tie-rod end, and the nuts on the bracket face forward as well. As the old saying goes: If it ain't broke, don't fix it.
It don't make a rats fannie, use a flex hose on the grease gun.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
Moderated by  Dusty53
