| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | Ok, here's an easy one: Should the zirk fittings on my tie-rod ends point towards the front or the rear of the truck? I doubt that I'll ever have to grease them again but would like to do 'em right.
Same question on the locking brackets that lock the ends into the tie-rod: Should the nut be facing the front or rear? Want to make it easy on my alignment guy.
Thanks - Bruce | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | I would point the zirks in whatever direction it makes it EASY for the guy running the grease gun. Jerry
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I would leave them pointing whichever direction they are when I got them tight.  | | | | | Joined: Sep 2011 Posts: 255 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 255 | I think that deserves a rim-shot! So I found a picture from when I pulled the truck apart, it looks like the zirk fitting is on the front side of the tie-rod end, and the nuts on the bracket face forward as well. As the old saying goes: If it ain't broke, don't fix it. | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | It don't make a rats fannie, use a flex hose on the grease gun. | | |
