| | | Forums66 Topics128,041 Posts1,055,490 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 43 | i have just finished restoring my 65 gmc pickup. mt headlights work great but my taillights are very dim. does anyone know what my problem might be? sure would appreciate any help. | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | You may not be getting a good ground from the bed to the frame. If you have a voltmeter, check the voltage from the frame to the wires at the bulb socket. | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | 54 5-window 3100,
My rear tail lights are also dim. Where and how do you "ground" them?
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | You can test for this condition by running a wire from the taillight bolt to a good clean place on the truck frame. They don't need to be perminent connections for the test, just good clean connections. | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Just heard about an idea a fellow has reserched, using LED lights for his turn and tail lights, he gave us a demo and they were very bright
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Nov 2009 Posts: 239 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 239 | LED's will be brighter than conventional bulbs. However, that will not resolve a grounding problem.
Lucille, the tail lights are grounded through the sockets to the light brackets to the bolts and then finally to the body. If there is any rust along that path, then a good cleaning is in order. Paint can also act as an insulator.
54-5 window, above has the right idea.
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car. -Unknown-
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | LED's will be brighter than conventional bulbs. That depends on the LED. I bought LEDs to replace the stock tail/brake lights on my '03 pickup and they were dimmer than the incandescent bulbs. I also bought EXPENSIVE 6v LEDs for my '38 and they were no brighter than stock bulbs.
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I powder coated both the tail light buckets and the mounting brackets on my 49. I simply ran another wire which I soldered and screwed to the flat strip inside the bucket which holds the bulbs. I attached the other end to a clean spot on the chassis. Works like new. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | As previous posts have stated, getting a good ground is essential. You might also want to ground motor to frame, and cab to frame. Pretty simple and inexpensive to do, and saves some headaches in the future. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | olblu49 - I might try that.
You can also paint the interior of the buckets white. It will reflect a lot more light and make them look brighter. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | When you are checking the ground, have a look at the bulbs, and make sure they are the proper CP. You never know what a previous owner was up to!
You can also use your Volt-Ohm-Meter to check the resistance for both the tail light ground, and tail light circuit too. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That's an excellent point. My '38 had a pair of #63 bulbs in it when I drug her home with a total of 6 whopping candle power as a brake light. She's good to go now though with 6cp tail light and 27cp brake light.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I sprayed the inside of the housing with some spray can chrome paint and it helped the 37. | | |
