6 members (Chevyeagle, Patharr, 54farmtruck, JoeDude, 2 invisible), 63 guests, and 1 robot.
Topics128,217
Posts1,057,495
Members48,473
I purchased this the truck near Bend Oregon in 2009. My wife and I took a trip and looked at three trucks of the same vintage all in the same area. The price ranged from $2-3.5K. This one was the last one we looked at and by far the most complete. It was running when I bought it for $3K. It ran and was driven on to my car carrier.
I live in Brush Prairie WA just over the Columbia river from Portland OR.
We brought it home the following weekend and it sat for a year. The truck only had surface rust. Bend is high desert area. This truck had a title from Idaho last registered in the 1970's.
I am doing a body off restoration.
I dismantled the truck in the summer of 2010 and started the sand blasting and painting of all the chassis. The down-side to a truck that ran so long is many parts are very worn. This will be my daily driver to work when complete.
The engine is a 1953 block 216 with a three speed. I will keep the truck close to original. Replaced the rear diff gears with 3:55. The tranny is 3 speed and rebuilt now. The engine is being rebuilt in Portland and will have shell bearings instead of the poured in place babbit.
The color will probably be Export Blue but with a black interior dash and tuck and roll seat.
So here I am.
Gene Wirth
1946 Chevy 1/2 Ton
Looks like you're well underway. Welcome to the Bolt! Keep us posted on your progress.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Lookin good !!
1940 Chevy KC 1/2-Ton
About 20 years ago I restored a 1953 Chevy 1/2-ton but not a complete frame off. I got interested because I purchased a 1996 Dodge Stratus to fix for my daughter. What a nightmare. It made me long for the simple non electronic days.
Nice work man - looks like you got it goin' your way.
Gene, just a note to let you know I think your doing a fantastic job on your truck. I can appreciate the attention to detail your giving it. Hope your riding soon and from the pace your going it won't be long. Oh, nice dog to. He helps when nothing else goes right....right!!!
Thanks for the comments. Do you know the paint type and color on Old Blue? Thanks.
Gene,
Great job. Loved the photo's.
Here are some sites that have been a valuable resource for me. Check them out and see what you think.
Harold
Old Car Manual Project -- this link is directly to the CHEVROLET SHOP MANUAL 1942 and 1946 MODELS page.
This one is a PDF that you download.
THIS ONE is Master Part Catalog for 1929-1954 Chevy. The links INSIDE that page don't work but at least you can tell what is available in the catalog.
Last edited by Peggy M; 06/01/2024 5:40 PM. Reason: fixed and removed the broken links
Harold
Very nice job Gene. Love the attention to detail! And you've accomplished it very quickly. Have fun and good luck!
Dan
Thanks for the links and the nice comments.
I see your wood worker. That's my where my real talent lies. What do you do wood working wise. I taught HS shop in the early 80's.
I have just about completed installing new electric wiper motors in my '46. I wanted it to look original.
I purchased the motors from Jim Carter and removed the plastic housing and switch. I did a little rewiring to remove the built in wiper motor switch. I then took the vacuum motor controls and adapted them to an electric switch and faux mounted the remainder of the controls. I had to grind out the center chrome exterior anchor parts of the original wiper motors.
I have a little more cosmetic work to finish. If anyone wants the whole story let me know and I'll provide the details.
Very nice! I'm going to convert to electric wiper motors in my 37. I'd be very interested in the details of your conversion. I'll send you a PM with my email address. Thanks!!
1937 Chevy pickup
1952 MGTD
Looks GREAT!
Your Truck looks great. You have a final color in mind? I am at least a year away. I hope to have it running by the end of winter.
Thanks, I'm thinking of two tone orange pearl/white diamond pearl with a touch of ghost flames. I've had a lot tell me to leave it like it is but I have to finish it. LOL. As soon as I finish the wiring on momma's 52 deluxe I'm going to tear it back down. How long have you had yours? It's coming along nicely.
GW,
Why did you choose not to use the Newport Engineering type with one motor and a synchronizing linkage?
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
I don't know about it. Is it 6Vdc and will it fit into the Valence area and still look original? You have a link to a place to view and purchase it? I am done now but's always good to know about. Thank You.
No
Yes
Yes
Yes - Bowtie Bits dot com
Didn't realize you were still on 6v or I wouldn't have mentioned it.
TGT,
What is the part number at bowtiebits.com?
A search of their 34-46 on-line catalog shows a 12v wiper. It would be very nice to know if they have a 6v wiper.
People (myself included) have posted in the past that they have bought a "6v" after-market wiper but found that it turned slower than the old vacuum wiper. After calling the vendor, some of us were informed that the 6v and 12v wipers were the same - it would just work more slowly in a 6v system.
Depends on how badly you want it, but you could find a 6v to 12v transformer, hide it under the dash and run a wire up to the motor. If you're really good you can make your own. Just make 2 coils of copper wire, one with twice as many coils. Maybe a more electrically minded poster can chime in on exactly how.
I doubt the 6 and 12 volt motors are the same. At 6 volts the current doubles. I hooked these up on a power analizer at work and they drew slightly over 2 Amps no load. The speed was about what I would consider normal. I considered adding a speed control but decided it was not worth it. You could add a 6 - 12 Vdc DC to DC inverter but not a transformer. A transformer will not work on DC.
That sounds like a nice looking ride. I bought my truck in the Bend Oregon area and it only had surface rust. I started the dismantling in the summer of 2010. Sandblasted the frame Axle etc. Changed the gears in the rear end did the breaks, shocks...... etc last winter. I painted the cab and 10,000 cab parts this summer. Had the machine work done on the engine this spring, rebuilt the tranny and installed all the drive train over the summer. Now I want to get the electric and cab interior done this winter. Then more body stuff in 2012.
Originally Posted by GWWirth
I doubt the 6 and 12 volt motors are the same . . . .
6v and 12v motors are not the same.
The motor I was referring to was one for which the vendor said that the 6v and 12v wipers that they were selling were the same unit. They said that unit was made to run equally well on both a 6v and 12v systems (as if they would perform equally well on both systems). Of course, that was a ridiculous assertion by that vendor.
That vendor gave my money back and paid for shipping both ways.
I suggest that anyone who thinks they are buying a 6v wiper (for a 1946 truck, for example) should first ask if the company sells a different unit for a 6v 1946 truck and 12v 1946 truck.
Sweet truck. I love the blue. I also agree with the 10,000 pieces to paint. I still have 5,000 to go.
Another 12 volt option is to modify a MG cable drive wiper system. There is a forum on the jalopy journal that a guy wrote the instructions with lots of pictures.
I am in the process of building the MG system in my 46. The MG system costs me less than $50. The Cole-Hersee switch for dynamic parking is the most expensive piece but you get intermittent and wash features with it.
1946 Chevy Half Ton
('56 235, '86 T5, '79 Camaro Z28 rear end, working on the '85 Jaguar XJ6 IFS)
1976 Margay Panther X, MC91B
I checked that post out and what a cool set up! Take pictures of your installation.
I am very interested in the subject here, as I also want to change to electric wipers. I have been researching the idea of the inverter for a 12v motor from a 6v battery. However I would like to see the link that you mention for the MG system
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
Jim carter lists a 6volt motor
6 volt motor
He also list a 12 volt motor.
12 volt motor
Tim
1951 3100 Chevrolet
Moderated
Moderated
Have just purchased a 6v wiper motor and would be interested in how you converted it back to the original knobs as the one I got had a turnabout switch?
Wayne
We would have to know the style of knob (knobs, you posted - are there multiple knobs on yours?)?
Where did you buy it and what is the part number?
What is the make/year of your truck?
Moderated by  J Lucas
