4 members (Jay R, Eisenholtz, Shardean, Otto Skorzeny), 79 guests, and 2 robots.
Topics128,023
Posts1,055,366
Members48,420
#813543 01/05/2012 4:34 PM
V
V Offline
# 8846122 on the trans, looked to decode but haven't found where to do that. Thanks for any help.
'57 3200
What did it come out of? What you have is a casting number, not a part number and casting numbers are not given in parts books. Hollander uses casting numbers, but they are not indexed.
V
V Offline
Not certain what it came out of hence my question
'57 3200
ODSS President
ODSS President
How many holes in your shift side cover?
~ Cosmo
1949 Chevy Half Ton
Cosmo #814820 01/09/2012 5:32 PM
I have a standard 3 speed and two 3 speed overdrives with the casting number 8845122. On yours the 6 could be a 5. In which case you have a SM318 GM trans with a BW R-10 overdrive. They have a 4 bolt side cover and a non syncro first gear. This trans was used from 55 through 65. There are some minor differences between cars and trucks. On the trucks the lower mount holes are threaded. There are also some differences on the side cover and the shift arms. There should be a date code below the casting number. Something like B 15 7 which would be Feb 15 1957.
Fred
V
V Offline
Thanks to all for your input.
'57 3200
