| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 35 | # 8846122 on the trans, looked to decode but haven't found where to do that. Thanks for any help.
'57 3200
| | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | What did it come out of? What you have is a casting number, not a part number and casting numbers are not given in parts books. Hollander uses casting numbers, but they are not indexed. | | | | | Joined: Dec 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 35 | Not certain what it came out of hence my question
'57 3200
| | | | | Joined: Jan 2001 Posts: 1,421 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,421 | How many holes in your shift side cover?
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | I have a standard 3 speed and two 3 speed overdrives with the casting number 8845122. On yours the 6 could be a 5. In which case you have a SM318 GM trans with a BW R-10 overdrive. They have a 4 bolt side cover and a non syncro first gear. This trans was used from 55 through 65. There are some minor differences between cars and trucks. On the trucks the lower mount holes are threaded. There are also some differences on the side cover and the shift arms. There should be a date code below the casting number. Something like B 15 7 which would be Feb 15 1957. Fred
| | | | | Joined: Dec 2011 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 35 | Thanks to all for your input.
'57 3200
