| | | Forums66 Topics128,179 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#81356 08/12/2007 5:34 PM | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | The truck is a mutt. 1952 5-window cab on what I assume is a 1950 1 ton frame. It has rear duallies and a dump bed . . . that actually works.
I got it home yesterday and got around to trying to identify it today. The number stamped next to the distributor 0249684 F54Z. The first character might be an O instead of an 0.
I would eventually like to identify the frame to find out what year it is. The engine has four bolts holding down the valve cover and a single pushrod cover. Doesn't appear to have captain's bars.
The VIN decoders I've tried say that the engine is out of a 1974 pickup truck. That seems kind of unlikely.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
#81357 08/12/2007 5:36 PM | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Sorry. I should have mentioned that it's a Chevy.
#81358 08/12/2007 5:39 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It's a 1954 235ci truck engine, Scott | | |
#81359 08/12/2007 7:26 PM | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Hey, Scott. Nice to hear from you. How did you decipher that? As I said, the VIN decoders I checked didn't come up with results that I believed.
BTW, guess where the Rochester B off that 292 is going? I think a Holley 350 two barrel might be a little more appropriate for the 292.
#81360 08/12/2007 8:51 PM | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | Looking at page 24 Section 10 of the 1954Salesman's truck data book, it looks like F54Z was 235.5 cu. in. engine for model 1508 Sedan Delivery | | |
#81361 08/12/2007 10:30 PM | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Greg_H, that's odd, or rather another odd thing. The cab isn't original and now the engine isn't original. Fine with me since the '51 4400 also has a '54 235 in it. The '54 engines must have been special in some way. On the other hand, when did the first high pressure 235s become available? Maybe that's why I have two of them in earlier model trucks.
#81362 08/12/2007 10:37 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by starkweatherr: The '54 engines must have been special in some way.
On the other hand, when did the first high pressure 235s become available? Maybe that's why I have two of them in earlier model trucks. 54 was the first yr for full pressure, good engines ya got there | | |
#81363 08/12/2007 11:48 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Originally posted by starkweatherr: Hey, Scott. Nice to hear from you. How did you decipher that? As I said, the VIN decoders I checked didn't come up with results that I believed.
I got it from my "Cars and Parts Truck ID Numbers" book. "F" stands for the assembly plant in Flint, 54 is the year, "Z" is for the 235 engine from a 1500 series truck (sedan/delivery I think). Sounds like the heatwave has put your projects on hold, it's definately slowed mine up some. Hopefully it will break soon. Going to the Kansas City meet? Scott | | |
#81364 08/13/2007 12:55 PM | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | 64Fleetside, it was pure dumb luck. I couldn't identify either of the engines from the pictures of the vehicles. Because of the shape of the valve cover on Dumpy, and the front mounted oil filler, I had almost convinced myself that it was a late model 292. That would have been great because I wouldn't have to worry about fabricating a motor mount, and I already have one 292, thanks to Scott. So I could have driven the truck long enough to get one engine rebuilt and do a quick swap.
Oh well.
Scott, when is the Kansas City meet? I'd like to go and I'm pretty sure my wife would also.
#81365 08/13/2007 3:46 PM | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Starkweatherr, Read all about it here , Scott | | |
#81366 08/13/2007 5:43 PM | Joined: Jul 2007 Posts: 66 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 66 | I am trying to decode my engine but I am not having much luck.
I have a 53 GMC. The number stamped by the distributer is: XC459392.
There is another on at the front bottom of the block: 3695408.
Any ideas what type of engine this is ? | | |
