| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | Va. 1952 tags use the 51 plate with just a metal corner, about 1 1/2 inches X 1 1/2 inches, with the 52 on it that u bolt on over the 51. Korean war times saving metal no doubt. DMV will let u tag truck using these odd plates. I bet most people think the owner just did that to change the year on his own!! I also have the county metal tag that was used back in the day. Both will go with the truck when I sell it this spring if the new owner is from Va. I wonder what other states did this or something simular and can u use em today?
'52 3100 "once a Marine, always a Marine!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | New York state had no 1954-specific full-plate. A new vehicle registered in NY in 1954 used a 1953 plate with a small 1954 metal plate that covered the 1953 in the lower right corner. Also, only one plate was used on NY vehicles at that time.
Yes, you can use original Year Of Manufacture plate(s) in NY. It is easy to do (have have plates for three 1954/55 vehicles). The plate(s) must be original paint and the number/code must not now be in use on any other NY plate.
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | MO is the same way. I think the plates were used from 47 or 48 thru 52 or 53 or so. The Truck tags are red plates with white letters and different color metal year tags. The one on my 51 is yellow w/black writing. http://farm3.staticflickr.com/2527/5740963414_ac46d31f5a_m.jpg | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I have a 1959 Chevrolet with 1959 South Dakota plates. These plates have the small tag on them also.
Bruce | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Minnesota did that until they came out with the stickers to change the year. At first, the new tag went in the upper right corner. A couple years later they domed the tag so it would go over the embossed numbers of the previous year, and moved it to the lower right corner. | | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | During WW11 Wisconsin had a plate made from soybeans,if you got the vehicle around farm animals they would try to eat them. | | | | | Joined: Nov 2010 Posts: 304 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 304 | interesting thanks for the replies
